General => Random Chat => Topic started by: marko on April 10, 2014, 12:19:37 pm
Title: Caliper paint removal method
Post by: marko on April 10, 2014, 12:19:37 pm
Recently acquired a set of r32 rear calipers painted but i want to change the colour.been trying to wire rush the old stuff off but its proper caked on...anyone suggest a good remover ????...or is bead blasting probably the only real way to get back to standard metal finish???
Title: Re: Caliper paint removal method
Post by: xjay1337 on April 10, 2014, 12:27:21 pm
Depends what you're looking to do. If it's baked on that much then a simple sanding block to level the surface followed by a paint preparation wash/wipe and then primer/direct to paint will be fine.
Post by: marko on April 10, 2014, 12:32:01 pm
Problem is they are yellow..lol..I've been using wirebrush attachment on the drill but gonna take me hours unless I can soften this stuff up
Post by: xjay1337 on April 10, 2014, 12:34:27 pm
If it's on there solid you don't need to remove every bit of last paint.
Just get off what you can, and primer and paint over it. Far easier. They are also only brake calipers..
Post by: Tortaruga on April 10, 2014, 01:22:20 pm
A blowtorch would be very effective. There may be knock on effects however...
Post by: Wooosh on April 10, 2014, 01:28:29 pm
Get them sand blasted and powder coated in the colour of your choice would be easier.
Post by: rich83 on April 10, 2014, 01:51:04 pm
Do not powder coat brakes..... you need to paint them.
Post by: MizGTi on April 14, 2014, 07:34:39 pm
I had a similar issue with my s3 front brakes. Initially used emery cloth to sand it and then used a wire brush. Did the job. Came out okay for a first attempt.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F04%2F15%2Fezezesa6.jpg&hash=63470488b10aabceedb69a4db980b4a4743053e2)
Post by: marko on April 15, 2014, 12:36:00 am
Looking good mate..well done!!!
Found nitro-mors to be the job at getting old paint off
