All Things Mk5 => How to Guides / Troubleshooting => Topic started by: shayd on April 12, 2014, 11:53:10 am
can some one please help i fitted my revo intake yesterday that i bought from a forum member but for some strange reason can not seat the maff in correctly as when i screw it in it pushes the other side out
i am using the original screws from the old housing
or are there suppose to be different screws to fit can some one please shed some light on this ?
This is so hard to read, you really need to use comma's and full stops. But to your question, pretty sure it uses the same screws. You just need to use sequential tightening. (half turn one then swap to the other) until it goes in.
I could read it lol
.. Most intakes come with new little bolts.. Belive the standard ones are like little self tappers for plastic... Pritty sure you should have new bolts.. You may damage the threads if that's the case and you keep trying
The revo intake should have come with two revo supplied bolts to fix the maf.
Thanks for the quick reply guys, are they all standard sizes for the after market intakes , if so can anyone help with the size so I can go and get some .
Or am I better off contacting revo for some ?
Any engineering retail merchant should be able to sort you out if you take in the intake providing you haven't messed up the threading by using the original bolts.
looking close at it when the maff is seated.
The holes were the screw goes through, the maff is not touching the intake on both sides,
am i better off putting a washer in between you recon guys.
Sounds like your maf aluminium plate is bent as it should seat perfectly with the intake.
all sorted guys all on and sounds sweet :happy2:
thanks for all the help
Glad you didn't damage it lol
