All Things Mk5 => Mk5 General Area => Topic started by: chris-182 on April 14, 2014, 09:53:05 pm
hi all, does anyone know where I can get hold of a standard rear anti roll bar from? anyone selling one on here? just spent £1400 on the car so not quite got the cash for a whiteline just yet and mine has snapped :(
Can anyone shed any light for me?
Found a few second hand ones on ebay but are all for 2.0 TDI / 1.9 TDI / 2.0 SDI. Are these all the same or different fitments?
I think the fitment is the same, with exception of 4wd models, but the diameter and construction of the bar will vary between models.
Eg. Some are thicker than others, some are solid, some are hollow.
I have collected some info on this myself... I'll dig it out.
Jas
Ive got one in the loft. Not practical to post it tho.
Jas
Cheers for that! if you could pass the info on I'd appreciate it :)
Ok, sourced from various google searches along with etka, here is the info I have so far.
I don't think the 4WD ARBs will fit a 2WD model, but I have one in the garage, im going to compare and see the difference soon.
Looks like the one to go for, if you can find it, is the Passat R36 ARB. Its a 23.6mm (same as GTI) but is a solid bar, rather than hollow.
Although the GTI version is probably easier to get hold of.
This table may not display properly in Tapatalk.
Front ARBs
| Car | Diameter | Wall | Part No |
| Golf V GTi | 23.6 | 3.5 | 1K0 411 303 BK |
| Golf V TDI 1.9 | 22.5 | 3.5 | 1K0 411 303 Q |
| Golf V GT TDI 2.0 | 23.6 | 3.5 | 1K0 411 303 BK |
| Golf V R32 | 22.0 | solid | 1K0 411 303 AQ |
| Golf VI GTi | 23.6 | 3.5 | 1K0 411 303 BK |
| Golf VI R | 22.0 | solid | 1K0 411 303 AQ |
| Passat R36 | 23.6 | solid | 3C0 411 303 AA |
Rear ARBs
| Golf V GTi | 21.7 | 3.0 | 1K0 511 305 DF |
| Golf V TDI 1.9 | TBC | TBC | TBC |
| Golf V GT TDI 2.0 | 20.7 | 2.8 | 1K0 511 409 CA |
| Golf V R32 | 21.7 | 3.0 | 1K0 511 409 BF |
| Golf VI GTi | 21.7 | 3.6 | TBC |
| Golf VI R | 21.7 | 3.6 | TBC |
| Passat R36 | 21.7 | 3.6 | 3C0 511 409 E |
Jas
Thought the gttdi was the same one
I have a standard rear gti roll bar lying around where you based
PM'd
cheers for the help guys! managed to sort one for £27 posted :)
I've also got a standard rear arb from an ed30...let me know if u want it,won't charge u for it,only p&p
Can anyone confirm the part no for the rear arb for gti?
Is it same as GT TDI 1K0 511 409 CA?
that's very kind mate! if this one falls through I'll take you up on that :)
No probs mate...where u located in the uk?
in I'm Warrington mate, where are you?
I'm in Hampshire mate..
