All Things Mk5 => Mk5 General Area => Topic started by: V2 FAN on April 17, 2014, 11:03:04 pm
Title: Retro fitting headlamp washers for Xenon
Post by: V2 FAN on April 17, 2014, 11:03:04 pm
Hi All,
Just bagged myself some Xenon lights with auto levellers.
So to complete the setup I assume I need to order the following parts ?
Headlight washer loom - Part number not yet identified.
Pump for headlight washers £47.58 - 3B7 955 681 also N903 038 01 this is the O-ring for the pump
Gasket - 431 955 465A
Lift Cylinder - 1K6 955 978A x 2
Speed nuts - n909 591 01 x 4 - 2 per cylinder
Nozzle carrier Left - 1K6 955 103
"       "     "     Right - 1K6 955 104
Cover cap Left - 1K6 955 109 GRU
"          "   Right - 1K6 955 110 GRU
If cover caps are required I will order the primed ready for paint variants
Left = 1K0 807 717 B GRU
Right = 1K0 807 718 B GRU
Adaptor - 1T0 955 665
Connector - 1J0 955 665E x 3
Hose in 10m length - 1J0 955 964F
Angled piece - 1J0 955 665A
Junction - 7L6 955 873
Terminals - 1J0 955 846 x 8
Cable tie with terminal socket - 3D0 971 838E x 1
Washer bottle - 1K0 955 453 S 5.5ltr - £33.48
Water level switch  - 7M0 919 376
O ring - 7M0 919 382
Flat contact housing - 7M0 973 202
I will update costs as I go along  :scared:
Thanks All  :happy2:
Title: Re: Retro fitting headlamp washers for Xenon
Post by: marko on April 17, 2014, 11:15:53 pm
In the process of getting this stuff together myself..
Think someone did a thread on this already with the prices attached
Could ideally do with having a good look at a car with everything fitted already so i can see what I'm short of
Post by: V2 FAN on April 17, 2014, 11:17:31 pm
Hi
I'm still searching through old posts, most of the stuff posted above is copy & paste.
Bloody complicated long list lol for something that throws water at the headlights  :stupid:
Post by: skard on April 18, 2014, 09:31:48 am
I did it on my last mk5 just for the sake of it, probably cost a couple of hundred quid and that was a combo of old and new bits to complete it.
I'd suggest getting the 5.5L bottle from TPS/a dealer as it came pre drilled with the holes for all pumps and sensors you need.
As for pics, look for a guy called Maloosheck on VW Vortex as he had pictures of the routing on his.
I got the loom from Kufatec and this also gives you the low fluid warning.
Post by: coolhandluke on April 18, 2014, 09:57:44 am
Have already got the washers  :happy2: just need the Xenon's.....but where??
Post by: V2 FAN on April 18, 2014, 05:07:59 pm
How about these bad boys http://goo.gl/oL2AMw
Or you could by the Xenon look alike ones and then sell me your washer kit  :evilgrin:
Post by: V2 FAN on April 18, 2014, 05:09:03 pm
Good pointers mate  :happy2:
Post by: coolhandluke on April 18, 2014, 05:32:04 pm
Thanx for that Link,Nice one,i Take it they are the real thing?
[qauote author=V2 FAN link=topic=82384.msg851484#msg851484 date=1397837279]
[/quote]
Post by: V2 FAN on April 18, 2014, 05:50:12 pm
I think they are as they are listed as original Hella units, I'm sure someone will be along to correct me if I'm wrong  :happy2:
Post by: SI-R32 on April 18, 2014, 08:41:02 pm
no where close to OEM units the indicator/side light housing does not go the full width of the light, but mk5's getting old now so more people will start putting cheaper non OEM stuff on there cars
Post by: coolhandluke on April 19, 2014, 05:36:11 pm
Thanx,shall give these ones a miss and keep my out for some OEM ones.
Post by: mk_boy85 on April 20, 2014, 02:12:10 pm
I'll sell you my whole washer kit if you want as I want to shed some weight off my bumper. It has the 2 pumps, pipe work etc.
Post by: V2 FAN on April 20, 2014, 02:20:45 pm
Certainly interested  :happy2:
PM me a price buddy  :pomppomp:
Post by: mk_boy85 on April 20, 2014, 02:39:32 pm
I'm not sure what it's worth so pm me an offer. I'll include 2 washer pumps with jets, bumper mouldings, pipe work to the washer bottle.
Post by: V2 FAN on April 20, 2014, 03:11:24 pm
PM sent  :happy2:
Post by: marko on April 20, 2014, 05:32:05 pm
Any pics of the full kit???
