All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Fozzy on April 25, 2014, 10:57:52 pm
Right I know this topic has even covered a few times but can't get to the bottom of this!!
Since fitting eibach sportlines to my edition30 57 plate I've developed a creak when on hard right hand lock!
Have since replaced the top mounts and due to a shock absorber leak replaced both front shocks! Mechanic says everything is fine but when cold a slight creak and when driven for a while goes?!
Almost sounds like it's behind the steering wheel behind the dash? Can you lube up the rack or get to it from under neath the car and what would I need to look for!
Driving me potty!!
Any help much appreciated?
