All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Chrisb1988 on April 26, 2014, 10:26:20 am
Iv been driving around for about 8 months with a slanted steeing wheel. Iv gone to get 4 wheel allignment done today and have found out that
N/S front is 20' neg
O/S front is 10-10 neg
So the O/S front i to far negative, does anyone know how toadjust it of if i have to buy any sort of shims?
Iv checked to see if anything is bent, the are no stress marks and all look true.
Please help
The only way to adjust front camber (unless you have adjustable top mounts) is to drop the subframe slightly and move it sideways until you have best optimised the settings, then tighten it up.
Most alignment places wouldn't think to do this so they typically fob you off saying it's not adjustable
Do you have a print out as I don't understand the measurements shown?
Cheers graymk5gti ill have a look in to it,
No i fidnt get one, i asked them to write down ervertythin i should ask, the measure ments are in minutes he said. If thats any help?
