All Things Mk5 => Mk5 General Area => Topic started by: CRAZY CATH on April 27, 2014, 08:49:11 am
does any one know if this is 2 or 4 door
1K0959433BT
i have tried ross techs web site but could not find it ??
thanks
1K0959433BT
thanks
The above part number is for 2 door.
thanks for the reply any ideal how do i find a part no for the 5 door i have been searching for hours :confused:
Letters FOR 4 door vehicles
AB
AM
L
CB
AK
Keep in mind that these part numbers are meant to be used in conjunction with your PR codes
Here's the decorder link read their help link
http://igorweb.org/equidec/
Your PR vehicle PR codes can be found in the front of the service book or in your boot on a sticker underneath the boot carpet.
Look at this link it will answer your questions
http://www.my-gti.com/2269
Get yourself a 30 byte CECM and you'll be able to code more items to work on your vehicle eg static cornering fogs etc!
This is what I mean
http://www.my-gti.com/2207/enabling-static-cornering-lights-in-the-volkswagen-golf-mark-v-with-factory-fitted-fog-lights
ok i see what your saying about the post not msg
my part no is 1K0 937 049 N
i have just found a list on ukmvivs that lists my part no as
1K0 937 049 N = 21 Byte (Highline) so is there any need to change it if that is right and i have a 21 byte highline any way ?
Post a link for that part number you said you got from ukmkivs - as it's not the same as your original question?
http://uk-mkivs.net/topic/26794-highline-cecm-can-anyone-help/
hope i have done this right really confused now
but thanks for helping
You done everything correctly and I can't see why your existing CECM will not work from the link you posted.
His link says highline so give it a go. :happy2:
Any problems come back there's always peps who will help!
oh well glad i posted the link right
all i am trying to do is get to the menu on my highline clocks :confused:
Remember when clocks are fitted it will have have to have the CECM coding altered to know the clocks are Highline.
So a box needs ticked with VCDS, similar to the cornering fog link if you at that as an example.
thanks again for the reply i have just been right through vcds cecm and i cant find any thing to tick ?
If I was you I would now send Eddie-NL a pm and see if he'll offer any advice,as he's done plenty of your type of mod!
Take a full scan of the car and have screen shots of the CECM module 9 for each byte so he can see what's ticked.
Worth a PM.
