All Things Mk5 => How to Guides / Troubleshooting => Topic started by: alexmccabe on April 28, 2014, 08:47:07 am
Title: New Thermostat Needed? | Solved
Post by: alexmccabe on April 28, 2014, 08:47:07 am
Right guys, advice please :)
My car temp sits at 75º instead of the 90º that it should be. Would this be the thermostat?
Title: Re: New Thermostat Needed?
Post by: skard on April 28, 2014, 08:50:30 am
It was on my ED30. If after 10 minutes of driving it is not at 90c & fluctuating when you stop/move off, then it is a safe bet.
Post by: GrayMK5GTI on April 28, 2014, 09:49:45 am
My issue here:http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.0.html
Was fixed with a new thermostat  :happy2:
It's a pig of a job to do at home, your best going to a specialist.  Part is around £25 IIRC
Post by: bacillus on April 28, 2014, 09:58:45 am
My issue here:  http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.0.html
fixed that link for you.   :smiley:
Post by: alexmccabe on April 28, 2014, 10:59:02 pm
Cool thanks guys. I thought as much. Does anyone have a part number for it, I read on that thread that it was a specific on for an Ed30, but mine is just a normal GTi.
Post by: skard on April 28, 2014, 11:23:22 pm
The GTI has a different part number, think it ends F not H but have a look to confirm that.
Post by: alexmccabe on April 29, 2014, 09:34:09 am
06F 121 111 F
Does this look right to you? It's all I can find.
Post by: skard on April 29, 2014, 12:31:05 pm
Yes for a GTI, or part number ending H not F for an ED30
Post by: teginder81 on May 01, 2014, 12:17:43 pm
The problem is that the gauge may be inaccurate, that is very cold for an engine temp. If the gauge is correct you may have a thermostat stuck in the open position. If this is indeed the case you had better change it as your engine mixture depends on proper engine temp.
Post by: GrayMK5GTI on May 01, 2014, 12:24:24 pm
The gauge IS inaccurate. Best doing the trick with the climate to see what the sensors are reading. 75 degrees on the gauge will be around 60ish degrees in the climate display
Post by: skard on May 01, 2014, 01:22:58 pm
Should say I diagnosed mine off the Fiscon readings, the gauge first gets to 90c when it is about 75c
Post by: alexmccabe on May 02, 2014, 09:25:49 am
Okay, so how do I go about getting this to appear? I'm assuming it is on the climate control displays?
Post by: GrayMK5GTI on May 02, 2014, 12:21:37 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.msg839035.html#msg839035
Post by: alexmccabe on May 03, 2014, 01:41:18 pm
Perfect thank you! Using that and speaking to my mechanic on the phone, I do indeed need a new thermostat. Thanks everyone!  :smiley:
Title: Re: New Thermostat Needed? | Solved
Post by: GrayMK5GTI on May 03, 2014, 03:29:27 pm
^ found your post in the middle of those quotes  :signLOL:
Glad your getting it sorted mate  :happy2:
I feel sorry for your mechanic, he is going to hate you  :ashamed:
Post by: alexmccabe on May 03, 2014, 09:50:11 pm
Ahaha, I didn't realise I did that. Fixed!
Ahh it's okay, he likes me :p I usually go to him with a few things as he is a fair drive away.
Post by: sgour on May 04, 2014, 10:43:26 am
Have the same problem myself... when driving the temperature only goes to ~70c but when I stop at lights etc.. it goes back upto 90c.
Hopefully getting it replaced later this week  :happy2:
Post by: Jarre on December 13, 2014, 09:46:19 am
Sorry to bring up an old thread, but is it just the one thermostat to be replaced? I'm having the same issue.
Cheers!
Post by: GrayMK5GTI on December 13, 2014, 11:24:04 am
The main one is the most prone to failing. Try that first.
Buy a genuine part  :happy2:
Post by: Jarre on December 13, 2014, 05:09:03 pm
Will definitely replace it with genuine.
The gauge sits at around 75 unless I'm stood still, then it will eventually rise. No fault codes so as with previous people, I assume it's the thermostat.
So is that the part number posted earlier, 06F 121 111 H for an edition 30?
Post by: Jarre on January 22, 2015, 03:33:39 pm
Just thought I'd update to say that it was the thermostat at fault. Cost me £180 all in for the genuine part to be fitted.
Post by: Alex157_gti on January 22, 2015, 03:49:46 pm
got mine done last week same fault seems to be common lately! on this forum  :surprised:
cost me a little bit more cuz of vat  :sad1:
Post by: Jarre on January 22, 2015, 04:28:44 pm
I was originally quoted £200 all in but they took less time than expected and knocked some money off which I was really impressed about - could've been too easy to just tell me it was the £200 they quoted! Mine was inclusive of VAT also, with a free bottle of screen wash and a £10 off voucher for next time :)
Post by: mart. on January 23, 2015, 11:01:11 am
Mines in today to get fixed with main thermostat. Granted its an A3 2.0T, but the same engine. Seems like its an awkward job.
Temp needle hasnt moved at all for over a month, and fuel economy has suffered. Garage are charging £170 all in with genuine part, so hopefully that fixes the issue.
Post by: Matthewsimone on January 23, 2015, 01:06:59 pm
So we know the temp gauges aren't moving up very fast but how is it effecting your heaters? Mine seems to eventually get to 90c or just under after about 15 minutes+ of dual carriageway driving but the heaters seem to only blow luke warm for a further 15 mins then they eventually start to blow as they used to and melt your face  :laugh:
Is this the same case for everyone else with suspected main thermostat issues?
Also even when mine is indicating nearly 90c on the gauge its actually only reading about 72c when we checked it through obd port using a digital scangauge!
Really hope its just the thermostat causing the issue and nothing more serious like heater matrix etc!
Could temp sensor/switch cause all these issues also?
Sorry to hijack thread but any advice/experiences be much appreciated
My main stat is being changed next week so fingers crossed  :confused:
Post by: Matthewsimone on January 23, 2015, 05:46:55 pm
That be a no then  :indifferent:
Post by: Jarre on January 30, 2015, 12:09:45 pm
Sorry I didn't see this reply....
I can't say that I noticed my heaters to not be working - I only got the car early December so it's been cold the entire time I've owned it and never been cold in the car. Also, my temp gauge never reached 90 on a dual carriageway/motorway, only at stand still or crawling traffic. It sounds to me like you may have a different issue!
Post by: pudding on March 24, 2016, 05:00:06 pm
Yep, mine was sitting at 75 and the heaters were rubbish, as was the mpg.
Changed it out today and it's a lot easier than people make out tbh.  Total cost was £70 for a new stat and sensor from VW, plus 4 hours of my time  :smiley:
Weirdly, the old stat was fully closed like the new one, but replacing it has done the trick, or maybe it was the sensor, who knows.  Good learning experience either way!
Heaters are now hot and the engine feels better, so well worth doing.
Post by: Shoduchi on March 24, 2016, 06:00:20 pm
It's a chronic issue that these engines have. People should check with VCDS or any other OBDII diagnostic tool what temperatures they run while driving, if they don't have PolarFIS or something like it to check the temps. :smiley:
