All Things Mk5 => Mk5 General Area => Topic started by: Chris92 on April 29, 2014, 07:54:51 pm
Title: What's needed for cam chain job?
Post by: Chris92 on April 29, 2014, 07:54:51 pm
I'm looking at changing my cam chain, I know il need the timing/locking tools but what do I need for the job itself?
Chain
Tensioner
What else? Any gaskets worth changing etc?
 :driver:
Title: Re: What's needed for cam chain job?
Post by: Paultc90 on April 29, 2014, 10:00:21 pm
I'm needing this done and was recommended that I do the belt and water pump while it was getting done.
Post by: Chris92 on April 29, 2014, 10:25:07 pm
I've already done the belt and water pump last year, cheers tho  :happy2:
Post by: Paultc90 on April 29, 2014, 10:27:16 pm
Ye this is the situation im in. Pump and belt have been changed so I'm waiting until they need done again and change the whole lot.
Post by: Chris92 on April 29, 2014, 10:39:16 pm
I don't know if your clued up and I know I ain't but if the chains rattling I'd get it done ASAP, the timing belt and water pump is at the other end of the engine and the cam chain is to the gearbox side in the cylinder head, I don't really see how the two are connected to the same job like how example when you change the belt you might aswell change the water pump at the same time as it's right there. But I don't see why you'd get the Cain done at the same time other than to save another trip the the garage, you won't save any money in labour  :happy2:
Sorry if you know all that already I'm not trying to be a know it all.
Post by: Paultc90 on April 29, 2014, 11:48:24 pm
It seems to be very common on early models which I have. A lot of people seem to put up with it. Been told it's very unlikely to snap. Tbh my knowledge is pretty limited, just going on what I've been told. Was recommended to get the whole lot done at once. Was looking to just get the chain done
