All Things Mk5 => How to Guides / Troubleshooting => Topic started by: BcPitta on May 03, 2014, 10:06:59 am
first of all thanks for looking, i tried to fit cruise control to my car yesterday everything went pretty smooth but now my wipers dont work ? i have connected another wiper motor and still nothing. i can squirt water at the windows but no wiper. ive checked over all the fuses a few times and can see no blown fuses. but if someone knows he exact one to check on a 1.9 tdi that would be a great help.
ive read the cars codes and it gave me this :
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,02,May,2014,17:39:50:32264
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W111282 Mileage: 224890km/139740miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC G000SG 6176
Revision: 12345678 Serial number: VWZ7Z0D0696008
Coding: 0000071
Shop #: WSC 01392 785 00200
VCID: 65CBAF4DAC7AE71
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021121
VCID: 3A712C317544B89
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
Shop #: WSC 00000 000 00000
VCID: 76E9F80101DC1C9
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00H30000 Serial number: 00000001072709
Coding: 00890F060004181E001400001400000000
Shop #: WSC 12345 123 12345
VCID: 3F875D256E669D1
Component: Fehler Lin-Slave 01
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 02 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0LK4XL
Coding: 0012338
Shop #: WSC 01373 785 00200
VCID: 31630B1DA8327B1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 500 0030
Coding: 0000002
VCID: EFE74D65FE86AD1
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 951 G
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0000401
Shop #: WSC 11111 111 11111
VCID: 2D5B176DB40A1F1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 270010492809AE
Coding: 3D0F0B40070003
VCID: 2953E37D80E2031
1 Fault Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 180
Mileage: 224896 km
Time Indication: 0
Date: 2000.00.00
Time: 02:04:41
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0716
Shop #: WSC 00447 210 04708
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
VCID: 30650E19A338729
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.2 1301
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F008F0F085B018010
Shop #: WSC 00724 210 104590
VCID: 7BFFE9353AFE411
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End ---------------------------------------------------------------------
any help will be very much appreciated. thanks
Might want to check the bonnet switch...
Bonnet switch works mate as it lets me squirt water which you can't do with the bonnet open. Thanks for your input though matey
Sent from my HTC One X using Tapatalk
The fuse must have blown or the wiring is not connected properly.
The CECM can't see the wiper motor
so that is either the LIN cable or power that has a break in the circuit
Also does your cruise work?
the steering controller is not coded and doesn't support it
hello buddy thanks for the imput, ive removed all the cruise control stuff just to see weather that was affecting it but no luck still. im thinking that the steering control modual may have got damaged some how so im off to see a vw wizz when he reopens tomorrow so fingers crossed. if not ill come back and post the results just hope this nice weather keeps up
SORTED! with a can of compressed air, went round all the stuff again and squirted every plug i could find so must have been abit of grime blocking the connection. 1 happy chappy!
