All Things Mk5 => Mk5 General Area => Topic started by: eltel on May 03, 2014, 03:31:29 pm
Hi all As title says. Should I disconnect the battery first???? :ashamed:
yes
Thank you for your prompt reply :congrats:
thier is a guide also on here how to do it :happy2:
http://www.golfgtiforum.co.uk/index.php?topic=121067.0
Ta da!
Cheers guys :happy2:
I would say it's not necessary... :confused:
Nope, Only time to disconnect the battery is when removing the battery, starter or alternator :wink:
Not necessary but better safe than sorry
Andy can I take it that you disconnect the battery when you're changing a light bulb?
I never disconnected mine.
Only time i have is to remove the air bag :happy2:
Didn't disconnect mine.
no only when doing the tyre pressures :signLOL: Just seen some right problems at work with the simplest of jobs from changing batterys to putting bulbs in
Im going to do it in the morning, I just wasn't sure if I needed to disconnect the battery before I start or is it like a plug and play thing?????
the light just plug and play--follow guide above and you will be fine
If you hear a beeping sound then the self destruct mode has initiated. Run for cover if this happens, otherwise its all good :laugh:
I thought I had this happen the other day turned out to be low washer fluid :grin: :grin:
Job done :pomppomp:I didn't disconnect the battery but I would advise safety glasses to be worn. Thanks for all the good advice. :congrats
That's what makes this a great forum
Did mine today too! Bit nerve-wracking when bits start cracking off but all in all, not to bad. Only lightly pushed into place and as going to get some trim tape and fix it in properly tomorrow as want to ensure it's was water-tight as possible.
MOT tomorrow so better pass!
