All Things Mk5 => Mk5 General Area => Topic started by: Black9 on May 09, 2014, 06:55:21 am
Title: Nurburgring
Post by: Black9 on May 09, 2014, 06:55:21 am
Made a last min choice to take my GTI over to Germany towards the end of May. Need some info regarding a few things...
My current Monza 2 wheels seem to have a slight wobble at high speed so plan to change them for the 17" Monzas or BBS CH/VZ and some sticky tyres (F1's, PS3?)
Belt was done around 60K, current milage is 95K, plan to get water pump and cambelt/tensioner replaced, brake fluid, engine coolant and transmission fluid
Also looking at getting a Short shift kit, any recommendations?
Brakes are stock but fairly fresh & should handle the ring fairly well or should I consider some more aggressive pads on the front?
Also considering getting an uprated rear ARB, car already has Eibach pro, WALK, uprated bushes etc.. Any other susp parts I should look at replacing such as drop links, balljoints etc? Car will need an Mot before I set off so tester should be able to pick up on anything that needs replaced!
The clutch and flywheel are stock Items and show no signs of slipping under boost, car is unmapped but considering going to R-Tech on way to ring for a cheeky map (heard great things about them) but still unsure about this as it could cause clutch issues?
Anything I've missed out? Any info appreciated
Also forgot to mention car has been dry stored for the past 8-10 wks. Any issues that this cld cause?
Title: Re: Nurburgring
Post by: GrayMK5GTI on May 09, 2014, 07:02:22 am
Brakes brakes brakes!!
Especially on your first time, you are going to give them a hammering. Upgraded pads & fluid is probably the minimum. I went in an R32 in 2012 and we managed to get those brakes pretty hot even with updated pads they were vibrating  :scared:
If you are on a stock clutch I would hold off the remap, it would be a shame to ruin your trip with a slipping clutch.
All handling mods and geo setup will be worthwhile  :happy2:
Stay safe & don't lose respect for the ring  :drinking:
Post by: Black9 on May 09, 2014, 07:05:18 am
Good shout on the brakes, would uprated discs & calipers be sufficient or should I consider a BBK?
Post by: anorganix on May 09, 2014, 07:47:37 am
I'd suggest Sigma 6 SS from Dieselgeek. Ordered mine, I can't wait to see how it performs.
I read that people are very satisfied with it and they had other SS kits previously installed on the car.
Clicky! (http://www.dieselgeek.com/VW_and_Audi_Short_Shifters_s/1830.htm)
+1 for brakes.
Good pads + discs and some good lines should do for now IMHO, but you can never be to careful. :)
Post by: Beddie on May 09, 2014, 08:42:11 am
You'll be fine on OE fresh fluid and decent uprated pads..
Driven correctly the Ring really isn't that hard on brakes, smoothness and good lines is key and there are plenty of sections that will allow your brakes to recover between heavy stops  :happy2:
Post by: Shorty on May 09, 2014, 09:37:16 am
Like said, brakes are very important. Fresh fluid and a good set of pads, maybe some Carbone Lorraine RC5+'s or DS2500's.
Tyres too! I wouldn't be bothered about going mad, if it's your first time I'd imagine you won't be driving absolutely flat out, it's quite a daunting place first time round. Get a good alignment and just do the normal checks, PCV, DV etc.
A remap would be nice for some extra 'oomph but not important.
Oh and enjoy it, such an awesome place!
Post by: Tfsi_Mike on May 09, 2014, 09:42:47 am
The diesel geek linkage looks great quality, seen it up close on the AKS Vrs, bit pricey though
Post by: anorganix on May 09, 2014, 10:02:44 am
True about both aspects.
Regarding the price, I got lucky because a mate (who supplies parts) had several kits ordered and managed to get a good price per kit.
Post by: Black9 on May 09, 2014, 04:09:46 pm
Thanks for the replies and info. My main concern just now is sorting a new set of wheels, ideally 17" Monzas to keep car looking sleeper as poss, cheaper tyres and as nimble as possible too. As for brake fluid, what's the recommendations? Where's the cheapest place for uprated pads also? Currently speaking to a member regarding Porsche BBK but starting to think I maybe over kill for my first ring visit.
As for tht diesel geeks SS, looks like a nice Pc of kit. Guess it's shipped from the US? Any other UK alternatives to the DG SS?
Wish I done a ring trip with my old ED30, 310bhp, DSG, 5dr, B12s & so much more. Virtually ready for tht ring, could have made things so much easier  :sad1:
Post by: greygti on May 09, 2014, 10:53:11 pm
Sound advise this
Post by: Jonathon555 on May 09, 2014, 11:08:28 pm
Brakes are important on a first trip as you will over use them due to lack of experience
However i would advise have the correct insurance as a big priority ..... Or only do a track day
Read you uk policy in fine detail , if your not covered and it goes south on you even due to dropping fluid and someone gets hurt.
It could be losing your shirt time.
Thats my 2p worth.
My ring holidays are now ended due to no insurance.
Post by: Wragg on May 10, 2014, 10:42:23 am
If your going for big brakes I think you might have to reconsider the 17" option..
Post by: Black9 on May 10, 2014, 12:20:27 pm
Doubt I'm going for BBK ATM, gonna run stock brakes with uprated fluid and aggressive pads. 17" Monzas would be ideal as they look totally OEM and cheap for tyres. Wouldn't mind some BBS VZ as thy fill the arches so much better than peacaras... TD 1.2 would be good but hard to find a pair ATM
Post by: Black9 on May 10, 2014, 12:20:56 pm
Has anyone used the forge or neuspeed SSS kit?
Post by: gobbleplease on May 11, 2014, 12:28:25 am
The car is a good fun drive even as standard to be fair, the worst thing about it is the brakes and would deffo be the first thing I'd do to it.
Post by: dan930 on May 11, 2014, 12:41:54 am
Sort the Brakes out & a proper alignment...also I think you need a helmet at the ring so don't forget that too
Post by: tony_danza on May 11, 2014, 09:24:25 am
The main things summarised.
Make sure the car is 100% fresh and safe.
A GTI is fine on stock brakes, the driver is the problem - you'll be over-braking and turning in too early, as everyone does for a good 20 laps until you get some sort of idea where you are on circuit.
You almost certainly are not insured, this doesn't just affect you stacking your car, but if you take out a GT3 RS or kill a biker - you're liable for that too. My TF days are over for this very reason, I only do trackdays or rentals which come with insurance options.
You should maybe go with a view to enjoying the road trip over in yours, and then pick up a rental for driving on the Ring, such as Rent4Ring or RentRaceCar.
Post by: DDM on May 11, 2014, 09:41:19 am
Is this not the same for everyone though, like enter at your own risk sort of thing? or is it if the inevitable does happen your actually liable. :happy2:
Post by: tony_danza on May 11, 2014, 12:20:50 pm
No, in the eyes of German law on TF days it's a toll road. They're all covered fully comp as part of their insurance, and normal road rules apply - we're subject to exclusions and clauses, so if you risk it and have an incident, you're really in deep ****.
Post by: DDM on May 11, 2014, 12:54:04 pm
a lesson learned, i had no idea. think i'd wait for a track day.
Post by: anorganix on May 11, 2014, 02:00:31 pm
There is a UK online shop that sells it for 250 quid, can't remember which one at the moment.
Later edit: found it; sold by BDM - click here (http://www.backdraftmotorsport.com/store/car-make-manufacturer/audi/sigma-6-short-shift-kit).
Post by: Pops on July 17, 2014, 07:11:56 pm
Hi Gobblespeed. Please can you pm about your golf for sale? Need to ask you some questions as may be interested! Thanks
Post by: RedED30 on July 18, 2014, 04:36:07 pm
It's not just when you go. Provision for when you get back.
As a minimum i would go with, new, known tyres that i have some confidence in. The Ring is that large you can get between 2-3 corners and have blazing sun to rain, so get a good allround tyre that YOU know are good. Provision to be replaced when you return.
At a minimum for brakes i would disks, new fluid, performance pads and uprated hoses - provision for the discs and pads to be replaced when you return.
Geo check, check your tracking, camber, caster to ensure you have a straight car.
Breakdown insurance. Cash for laps, a go pro, ears to listen to the locals and for other users.
