All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: DaneJD on May 16, 2014, 05:54:27 pm
Title: VW Touch/Bury Bluetooth kit with MFD2 and CD Changer?
Post by: DaneJD on May 16, 2014, 05:54:27 pm
Hopefully somebody may be able to shed some light on this, I am hoping to fit a VW Touch bluetooth kit or Bury bluetooth kit as some may know them to my 2005 GTI with factory MFD2 nav and CD changer.
My question is will I lose the CD changer function by fitting this? It's been removed from a 2010 Passat and uses the quad lock wiring harness system which I believe is compatible I just don't want to lose any of the standard functionality.
Thanks guys.
Title: Re: VW Touch/Bury Bluetooth kit with MFD2 and CD Changer?
Post by: J400uk on May 16, 2014, 09:18:01 pm
Shouldn't affect the CD Changer as it's a different connection. You might need to adjust a couple of the pins though if it's from a 2010 as the Bluetooth pin in the quadlock changed in newer models.
Post by: DaneJD on July 13, 2014, 12:12:15 pm
Thanks for the help
