All Things Mk5 => Mk5 General Area => Topic started by: matsu on May 18, 2014, 10:24:20 pm
Title: Engine noise can I fix it
Post by: matsu on May 18, 2014, 10:24:20 pm
Hi guys
I have an 05 gti so it has what I believe the ax engine which has always sounded like a diesel.
Despite getting cambelt /follower checked yet again it seems to be noisier than ever.
This is spoiling my 4yr love affair with the car.
Can I do anything other than an engine swap to resolve this issue?
I am now contemplating chopping her in,but am willing to do whatever I can to fix and therefore keep her!
Any ideas ?
If... I decided on an engine swap. Anyone got ideas of cost?
Oh and where do I source new lump from??
Don't want much do I lol
Thanks in advance
Matsu
Title: Re: Engine noise can I fix it
Post by: 56OctyVRS on May 18, 2014, 10:36:57 pm
A lot of the noise is from the direct injection and there is little you can do about it. Mine was only ever noisy at idle and I just ignored it.
Post by: matsu on May 18, 2014, 10:51:15 pm
Hi mate
Thanks for reply. It's mostly on idle. She still goes like stink lol
I'm finding it harder to ignore.
Matsu
Post by: bacillus on May 18, 2014, 11:34:33 pm
Not sure if a stretched cam chain would cause this noise. Maybe Alex could comment.
Post by: mvb12 on May 19, 2014, 12:38:59 pm
You anywhere near Peterborough?
I know I guy up there that gets a few engines in could drop you his number via pm.
expect to pay 600 and upwards
Post by: Paultc90 on May 19, 2014, 12:47:04 pm
I have the same issue. Been told it's the cam chain that's the problem.
Post by: Malyon on May 19, 2014, 01:00:27 pm
Iv got this issue with mine.
Went to my local vw specialist thinking cam chain and it isn't that.
See if it's a lot noiser when hot if so it's PVC valve.
Not changed mine yet due to them doing a new gens ration and in back order.
Don't panic about it tho won't cause any damage if it is PVC
Post by: edd666999 on May 19, 2014, 01:10:28 pm
Decat full exhaust...
Post by: SurreyED30 on May 19, 2014, 02:22:25 pm
all the GTi engines sound like diesels / tapperty mate, there's a few threads on noisy lumps on idle, most people say its the follower or fuel injectors. i thought my edition sounded like sh*te when i picked it up but searched the forum and my worries were gone.
by all means replace the PCV and cam follower for peice of mind though buddy, always helps to keep on top of things  :happy2:
Post by: matsu on May 19, 2014, 04:25:06 pm
Thanks guys
I'm aware of all tbe usual suspects -which I have had changed during my four years of ownership
Service I'd due so my new guy will go through everything and double check it all.
I was just wondering if a newer model engine would be a better fix
Or even go to k04?
I'll keep you posted.
Matsu
Post by: L17JDH on May 20, 2014, 07:21:48 am
Don't ignore it! my gti is a 2005 with the Axx engine and when I bought the car it sounded like an old diesel I had the cam chain and tensioner changed and problem solved.
I would say now the engine has the normal tapety gti engine noise lol but doesn't sound like a diesel which is the main thing.
Post by: matsu on June 05, 2014, 10:11:39 am
Mini update
I have wear on cam and water pump which is where the noise increase is coming from
Car serviced today. The replacements will be done soon as parts arrive
Also the injector fault code popped up after service
Anyone have this happen
My guy will look into it when he has the car next
As always thanks for any input
Matsu
Post by: Andy on June 05, 2014, 12:41:25 pm
sounds like the cam chain and tensior :happy2:
Post by: matsu on June 05, 2014, 01:38:59 pm
Cheers maxi
Will be done on a week I hope
Matsu
Post by: Mikes007 on June 05, 2014, 03:51:10 pm
My engine sounds like this to. But it isn't that loud. I think I'm gonna change the cam chain and tensioner to. Just to be on the safe side.
