All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Nico2904 on May 27, 2014, 03:54:22 pm
Title: RCD 310 into MK5 GTI
Post by: Nico2904 on May 27, 2014, 03:54:22 pm
What do I need to fit a RCD 310 in my Mk5 GTI from 2006? Will it drain battery and is newer canbus gateway required? If so which one to get
Cheers :happy2:
Title: Re: RCD 310 into MK5 GTI
Post by: Eddie-NL on May 27, 2014, 04:23:26 pm
You will require a gateway
I can offer new Pre-coded gateways for £75 delivered
Post by: Nico2904 on May 27, 2014, 08:29:24 pm
I've read that it is possible to reprogram the old canbus gateway?! Btw I have acces to VCDS
Post by: daedos on May 27, 2014, 08:42:50 pm
Good value just for the gateway. Is that £5 extra for the coding?  Otherwise your signature needs updating.
Post by: Degudodger on May 28, 2014, 10:31:03 pm
Can't reprogram older gateway's
Post by: Eddie-NL on May 29, 2014, 08:59:37 am
it is £5 for the coding
Post by: Nico2904 on May 29, 2014, 05:32:11 pm
Will this gateway, part # 1K0907530T be ok to use with a RCD310 with no issues? Or do you recommend any specific gateway?
Seems people are talking about the "L" one
Post by: Eddie-NL on May 29, 2014, 05:42:17 pm
I have a Q gateway which I'm selling cheaper £50 delivered, can be pre-coded
Post by: Nico2904 on May 29, 2014, 06:27:13 pm
Will that work no probs? Are there any differences in the gateways, i.e there are so many. L, Q, T, AA and so on?!
Post by: Eddie-NL on May 29, 2014, 06:31:24 pm
Yes will work fine
Post by: Nico2904 on May 29, 2014, 06:55:13 pm
Ok I'll take it  :happy2: do you have paypal?
Post by: joolstdi on June 02, 2014, 03:36:09 pm
i thought thant the RNS310 would work with the older canbus without any issues
with no battery drain.
Post by: DamoP on June 02, 2014, 04:21:57 pm
nope, all the newer VW head units require a new can bus, unless your lucky enough to get an RNS510 with correct firmware
Post by: J400uk on June 02, 2014, 07:29:23 pm
RNS 310 does seem to be fine oddly enough. I've yet to read any reports of it causing battery drain and I left mine parked for over a week recently without issue. I've got an ancient 1K0 907 530 F gateway.
Could it be because its made by a different manufacturer? Its loosely based on the hardware of the old RNS 300 too whereas the others were all new units when they came out.
