All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Karl_mac_ on June 02, 2014, 08:40:12 pm
Title: SEAT RNS310
Post by: Karl_mac_ on June 02, 2014, 08:40:12 pm
One on these has come up locally at a bargain price (sub £50), its been sold as a VW RNS310 stereo.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1050.photobucket.com%2Falbums%2Fs405%2Fkarl_mac_%2F0A859512-822D-4527-9361-687A1593040C_zpswx89nshy.png&hash=131efb8efb660947ccbd777d8440632dfb3250df) (http://s1050.photobucket.com/user/karl_mac_/media/0A859512-822D-4527-9361-687A1593040C_zpswx89nshy.png.html)
Will fit and work? If so do I need a can gateway?
Title: Re: SEAT RNS310
Post by: bacillus on June 02, 2014, 10:13:45 pm
It's a third generation unit so if it works you'll need a gateway that version L or above to avoid battery drain.
Post by: Stevie35 on June 03, 2014, 07:15:50 pm
It will work as they are also fitted to some VW cars, as said above will require correct gateway. Should be able to upload correct boot up screen for VW too.
Post by: J400uk on June 03, 2014, 07:16:31 pm
Wow that's super cheap! Yes it will work fine in a Golf, mines actually originally from a Leon.
You shouldn't need a new gateway either as no one has ever reported the RNS 310 specifically as causing drain, its only the RCD 310, RCD 510 and RNS 510 that seem to cause problems. I'm still using an ancient version F gateway and have left my car parked for well over a week without any drain whatsoever  :happy2:
Post by: Karl_mac_ on June 03, 2014, 09:46:13 pm
Excellent news. For that price I might as well buy it and sling it on ebay if it doesn't work.
How is easy is it to add a sub/amp to these units?
That means the wife will end up with my Pioneer now  :signLOL:
Post by: Viking on June 03, 2014, 10:15:57 pm
Make sure it has maps loaded on to it, and make sure they're as new as you need. There's no way to update the maps (or install them if they've been wiped) other than buying a new SD card from VW (or Seat) and that's not cheap.
Post by: yin on June 03, 2014, 10:18:37 pm
Is that the picture the seller has sent you?
Post by: usmangti on June 03, 2014, 10:30:10 pm
Check this item number out on eBay:
161323350767
Same pic states has a fault?
Post by: yin on June 03, 2014, 10:31:38 pm
161323350767
Thats why i  asked  :smiley:
Post by: J400uk on June 03, 2014, 10:32:21 pm
That's only for the RNS 315. The 310 maps can be had a bit easier with a bit of clever google searching and a blank cd/ SD card .... :wink:
Post by: BcPitta on June 03, 2014, 10:35:42 pm
i think everyone did the same thing copy and paste straight to ebay to try get in on the bargin haha too bad its faulty
Post by: usmangti on June 03, 2014, 10:37:41 pm
I thought I'd see what they're like and what they going for and the first one was that pic!
Post by: Karl_mac_ on June 04, 2014, 08:08:47 am
Looks like the same guy as their both in Sheffield, its through a mate of mate who didn't mention a fault. Luckily its local enough that I can go and have a look at what the fault is.
Thanks for the help chaps.
