All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Degudodger on June 04, 2014, 11:27:11 pm
Title: DAB Boot lid install - Part numbers
Post by: Degudodger on June 04, 2014, 11:27:11 pm
Guys,
With my RCD-510 DAB arriving in the next couple of days i need to order a couple of parts to mount the FM/DAB Amplifier Aerial.
I have the amplified FM/DAB aerial so what i need is:
6m fakra Extension cable
1m fakra extension cable
Adapter which clips to the Amplified aerial
Basically i need everything here apart from the DAB aerial
http://www.ebay.co.uk/itm/Volkswagen-Oem-DAB-Aerial-With-Fakra-Extension-Cable-6m-Rns510-Dab-Rcd510-Rns315-/281350999003 (http://www.ebay.co.uk/itm/Volkswagen-Oem-DAB-Aerial-With-Fakra-Extension-Cable-6m-Rns510-Dab-Rcd510-Rns315-/281350999003)
Does anybody happen to know the part numbers so that i can order from my local TPS.
Title: Re: DAB Boot lid install - Part numbers
Post by: Degudodger on June 05, 2014, 08:55:10 am
I have found everything bar the blue square connector that connects to the FM/DAB aerial to the feed from the FM amp.
