All Things Mk5 => Mk5 General Area => Topic started by: flyboy1976 on June 08, 2014, 09:28:22 am
Title: VW Repair wire help needed
Post by: flyboy1976 on June 08, 2014, 09:28:22 am
Hi all, I  think I know the repair wire I need ( I think I'm right anyhow) for pin 4 on the BCM is a 000979 025E or a 'MCP' small terminal from Kufatec (38253).
Basically I need the terminal and not the repair wire from VW. Can someone supply me with the terminal part number from ETKA please.
As an example a: 000979 009E repair wire uses a N 907 647 01 terminal
Can someone supply me the terminal part number that corresponds to repair wire 000979 025E please.
Cheers very much in advance
Title: Re: VW Repair wire help needed
Post by: Eddie-NL on June 08, 2014, 09:38:58 am
Not available from VW, they have reduced their terminals selection. And have a minimum order quantity when ordering
you will have to buy 50 from kufatec
Post by: fab5freddy on June 08, 2014, 09:44:10 am
What about bold sport? You can buy terminals from them iirc?
Kristen, i've a few different ones in the shed, if you can find a pic of the one you need i'll fire it over to you  :happy2:
EDIT:  http://www.bold-sport.com/store/index.php?route=product/product&path=48&product_id=71 (http://www.bold-sport.com/store/index.php?route=product/product&path=48&product_id=71)
Post by: flyboy1976 on June 08, 2014, 10:01:20 am
Cheers Guys really appreciate the replies,
Ed:
 I thought that might be the case with the 025E wire, I bought a Kufatec heated washer jet loom and installed it last night but when I went to connect the main live feed to connector A 'black' pin 4 of BCM (Kufatec instructions say connector B/white - pin 9) which both use the same terminal I noticed some wally had put a 009E terminal on the end ha ha....nice! hence why I now need a 025E terminal , but it looks like the repair wire is the only way or order the kufatec job lot, can you please confirm that pin 4 and 9 do use the 000 979 025E / MCP small repair wire/connectors please.
Fab 5 freddy - cheers bud but I think I will just make do with the vw repair wire, thanks very much for the reply though.
Post by: Eddie-NL on June 08, 2014, 10:40:20 am
it is pin 4
repair wire would be the best option
Post by: flyboy1976 on June 08, 2014, 03:15:17 pm
Ed: cheers very much indeed.
If anyone has a few of the ones from Kufatec I will happily send some pennies for a few please.
