All Things Mk5 => Mk5 General Area => Topic started by: mvb12 on June 16, 2014, 02:21:23 pm
Hi All,
Right, got a wee problem, i changed my steering wheel over to the mk6 wheel and since then my side mirrors have a mind of there own.
when I swapped the wheels over the mirrors kept moving by themselves. this has now resolved itself, but now the issue is the control switch.
When I adjust the right mirror, both mirrors move, but when i adjust the left it works as it should and only the left moves.
Anyone able to shed some light?
My golf has had the same issue since I bought it and as far as I know it hasn't had the wheel replaced.
It's a coding issues.
If you've got a high-line cluster it's a simple tick box if not it's VCDS To recode.
Tick box where in the highline.
If using VCDS what should the coding be?
This may explain it better
http://www.myturbodiesel.com/wiki/vcds-vag-com-tweaks-and-modification-settings-in-the-comfort-module-on-mk5-mk6-vw/
Both moving together is actually a feature helps you get the left hand one close apparently. My 05 golf has done it since I had it.
Simon
There didn't move together but in any direction.
Sorted it with VCDS now. Cheers guys. :happy2:
