All Things Mk5 => Mk5 General Area => Topic started by: Jayy26 on June 20, 2014, 01:04:07 pm
I bought some rs4-2 pads a while ago and fort they would stop squeaking or at least my everytime I slightly touch the breaks..I understand there track pads? But it's really annoying so does anybody no a fix or another set off good pads without braking the bank?
Seen some brembo ones for about 36? Of opie oils?
You could try taking the pads off and re-fitting with a smidgen of copper grease on the back of the pad
Whenever I buy brake pads I stick with pagid, can't go wrong with pagid stuff
i did take them on and put copper grease on (Y) but still the same...well today not as bad :/
and gthese pads are pagid :0
Yep mine are doing the same had them on about 200miles so far. Then again i replaced all my discs brand new aswell as the pads.
what did you buy the pagid ones?
im just going to put some brembo ones on the front because i cant stand the noise :/
mine have been on alot longer then yours have and alot more abuse i can imagine ..even managed to cook them and the sound went then gradually came back :/
http://www.opieoils.co.uk/product-finder.aspx?CategoryID=83&ProductTypeID=80&SEName=brembo-brake-pads#results
will these do at all?
cant be dealing with the squeaking noise off the pagid rs4-2 :(
No votes for Vaico? Haha I saw them on Ecstuning for almost half price of OEM. Semi- ceramic. Has anyone used them ?
thats the stuff!! i think people say its also slightly corrosive...
have you used the pagid rs4? and eliminated any off the noise?
just everytime i break its really annoying so want a good alternative :)
