All Things Mk5 => Mk5 General Area => Topic started by: markt on June 24, 2014, 10:14:33 pm
I have developed a clunking noise from the passenger side front at slow speeds and when turning on full lock at standstill. On further inspection the cv boot is covered in grease could it be the cv joint
Sounds like you have answered your own question there :happy2:
Other clunking noises at speed have been the subframe moving (fixed cheaply with a spacer kit)
Thought it was just wanted a 2nd opinion
2nd guess broken front spring?
Checked springs then noticed a nice load of grease all over the cv boot
I had a similar issue it was the cv joint.
If your planning on fixing yourself a new outer CV's about £30
Or a garage may charge up-to 2hr's labour .... So call it £80 at most garages (£40 p/h labour)
Outer cv joint changed yesterday creaking has now gone
