All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: Rob1 on June 26, 2014, 08:46:19 am
Title: Will a USA Gti highline work in a mk5 golf
Post by: Rob1 on June 26, 2014, 08:46:19 am
Hi all I am currently looking at a set of highline clocks from a USA Gti, does anyone know if they would work in a mk5 uk golf . The part is correct i.e. 974 replacing a 964 midline, I have read a topic previously relating to USA clocks but not sure if that was on this or another forum.
Thanks Rob1
Title: Re: Will a USA Gti highline work in a mk5 golf
Post by: skard on June 26, 2014, 08:52:04 am
Yes, but the foils will say degrees in F not C, they also have words instead of pics for some things such as BRAKE.
You could swap your foils over though.
I had US diesel clocks in my old car, there as an oil sensor that needed activating too so there may be some small changes to make.
Post by: J400uk on June 26, 2014, 12:40:56 pm
As above watch out for the oil sensor setting, I had that on a cluster I bought for another car. Without changing that the ECU may permanently log a fault code for 'no communication with instrument cluster'
Post by: Rob1 on June 26, 2014, 07:20:56 pm
Thanks for feedback guys, I'm currently contemplating the usa one as opposed to a uk spec one
Post by: Dave J on June 26, 2014, 08:27:33 pm
Works in my car a treat, but EddieNL fitted them  :notworthy: I asked him to swap the foils so that it looked like a UK cluster - I didn't like the USA 'BRAKE' & 'CRUISE' type where we have symbols...
Post by: Rob1 on June 26, 2014, 09:09:00 pm
nice one just what I wanted to hear, how long ago did Eddie fit them?
Also what are the foils?
Post by: skard on June 26, 2014, 09:16:06 pm
Foils are the printed circles with your speedo range, RPM range, fuel gauge and water temp, i.e., the round bits behind the needles.
Easy to swap the US for UK ones...if you are careful removing the needle.
I did this to my old car in late 2009, sold the car with them in 2012.
You have nothing to worry about, if they are cheap then go for it.
Post by: Rob1 on June 26, 2014, 09:34:59 pm
Post by: scopes on June 26, 2014, 09:57:44 pm
I have them fitted and quite like the Brake, cruise words on the dash, as its different looking !
