All Things Mk5 => Mk5 General Area => Topic started by: Bennz on June 29, 2014, 10:57:58 pm
I live in New Zealand which temp is around 28c max and 5c lowest.
For a 2008 MK5 GTI mainly road usages ( no track driving) ,but still want to unleash the power and possible do the APR Stage 1 only mod.
should I use :
Castrol Edge Titanium 0w40 or 5w30 ?
I'm planning to change the oil and filter every 5-7000 Kms .
5w-30
VW recommends 5W-30 over here.
I don't think you'll need 0W viscosity oil if you don't have below freezing temperatures.
Thanks, strange thing is VW dealer here either say Castrol edge 5-30 or shell helix ultra 5-40. Would the 40 be suitable for this particular engine under load and daily driving ? Or should stick to 30 :)
However I heard that neither of 5-40 or 5-30 mentioned above are long life oils.
Only Castrol Edge 0-40 considered long life which should be used even changing intervals are short.
So I'm confused
Castrol edge 5w-30 is long life oil and should be perfectly fine for you. Do a search on here about this topic, there are so many threads already. All the info you need will be there :happy2:
Shell Helix Ultra Extra is lthe long life oil, and would be my choice over the crap castrol.
Why Castrol is crap ?
Because they call it full synthetic when in reality it's not. They lie.... :happy2:
Shell is manufactured from full synth base stock while castol use hydrocracked petroleum base stock.
Full synth (true full synth) is a superior product.
I heard some oils are not recommended in some countries due to the sulphur in the fuel . Not sure which ones are not recommended for new Zelaand or Australia
5w 30
I emailed VW NZ to see what they recommend which is suitable for here . I personally though for turbo engine 5w40 would be suitable as offer both cold start and hot operational condition ( under load) protection
So basically I want to know if the 40 offers better protection than 30 ?
