All Things Mk5 => How to Guides / Troubleshooting => Topic started by: asht42 on July 01, 2014, 07:12:08 pm
Title: incorrect flow issue?
Post by: asht42 on July 01, 2014, 07:12:08 pm
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 122763 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:06:14
I
Been having an issue the last few weeks, had it plugged into vcds and got the above, thought it was the carbon cannister lid or the pcv but having changed the o ring and the pcv its still happening any one got any ideas?
Title: Re: incorrect flow issue?
Post by: bacillus on July 01, 2014, 07:16:47 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,84344.0.html
Post by: asht42 on July 03, 2014, 05:52:04 pm
Would this cause the car to stutter and bog?
Post by: GLIDN on July 04, 2014, 06:33:32 am
Had this error on all 3 my GTI's in the past 4 years. Additionally helped 5 other GTI owners as well.
If there are no visible breaks or leaks surround the Carbon canister. Then replace the N80 valve and superseded hose.
In a nutshell yourself or previous owner use to fill the tank up. Then decide to round up to nearest 50p or £, in affect adding more gas in.
As soon as I replaced my N80 and hoses also letting the tank full to where it stops automatically. I have never yet seen that error again.
Neither of my GTI's have this error anymore. 2+ years and counting.
Post by: v4rley on July 04, 2014, 09:12:17 pm
Wouldnt expect so, atleast didn't on mine.
Do you check the N80 valve with VCDS before changing?  I checked mine that way, listening for the clicks and seems fine.
Post by: asht42 on July 05, 2014, 02:16:40 am
Having spoke to volkswagen apparently it would got it booked into sort it next wednesday so I'll let you know
