All Things Mk5 => Mk5 General Area => Topic started by: Chris92 on July 05, 2014, 05:36:34 pm
Title: Loss of power after wash
Post by: Chris92 on July 05, 2014, 05:36:34 pm
I cleaned my engine bay today then dressed it, but now I've just been out again for the second time and it's still got no power. Feels like a NA engine now and there's no sound of the DV when I put my foot down. I covered the fuse box, intake etc and was careful when rising.
I've looked at the MAF plugs and fuel pump ones incase there were wet/damp but all looked fine, also pulled the coil packs out to check if the plugs weren't under water but they weren't.
Any ideas? You think it just a damp plug?  :scared:
The car idles fines to and sounds normal
Title: Re: Lost of power after wash
Post by: edd666999 on July 05, 2014, 05:38:42 pm
Did you disconnect the battery?
Title: Re: Loss of power after wash
Post by: Chris92 on July 05, 2014, 05:40:40 pm
No I didn't but I covered it, worth disconnecting you think and try again?
Post by: betty_swollox on July 05, 2014, 06:15:10 pm
This is why I am too scared to power wash me engine lol
just clean it by hand  :party: :party: :party:
Post by: Chris92 on July 05, 2014, 06:23:00 pm
I've done it a good few times with no problems at all,il still clean it again I'm sure after this little episode  :happy2:
Post by: dansmith180 on July 05, 2014, 06:30:52 pm
I always do my bay with the pressure washer, but I make sure my engine is hot first and run the engine whilst doing it and keep it on for 5 minutes or so after, that way you don't tend to end up with water sitting where you don't want it.
Post by: Saintsteve on July 05, 2014, 06:56:16 pm
Sounds like water in one of your connector plugs , maybe the one that connects to the Diverter valve?
Post by: Chris92 on July 05, 2014, 07:05:44 pm
I've been out yet again still no luck, so I've unplugged every plug I can see and sprayed the plug and sensor with wd40 incase water is sitting in there.
One things for sure I've mastered removing the stock airbox ha what a awful creation that thing is
Post by: Bennz on July 05, 2014, 10:04:14 pm
Be careful with Wd40 as it could trap water molecules underneath and cause actual rust.
Post by: Chris92 on July 06, 2014, 02:12:59 pm
All is well now  :happy2: went out just before to try it and it had it's kick back, must of just been a damp plug.
Post by: betty_swollox on July 06, 2014, 02:13:55 pm
good stuff genius  :stupid: :stupid: :stupid: :stupid: :stupid: :stupid: :stupid: :stupid:
 :signLOL:
