All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: th3_f15t on July 09, 2014, 05:38:14 pm
Title: Suspension Top Mounts
Post by: th3_f15t on July 09, 2014, 05:38:14 pm
So after some digging about and research + advise, I discovered that AmD Tuning are offering Bilstein suspension kits with free fittings (saving about £250ish, apparently). More info here;
http://www.amdtuning.com/news.read.cfm?articleid=5226
So anyway, I'm wondering if it's worth replacing the suspension top mounts (both front and rear) when changing the dampers and springs as a matter of cause (regardless of whether it's replacement OEM items or full coil-overs). If so, are there recommended ones to uses with after market suspension or just some OEM replacements from the normal parts distributors (Febi by Bilstein for example)?
Many thanks!
Title: Re: Suspension Top Mounts
Post by: SurreyED30 on July 09, 2014, 05:51:26 pm
Most on here including myself replace with TT/RS3 top mounts mate and there much stiffer than oem gti
Post by: th3_f15t on July 09, 2014, 06:48:09 pm
Have you got the part numbers to hand for all the bits I'd need? Also, prices I can expect to pay?
Are the TT/RS3 mounts for both front and rear?
Post by: fab5freddy on July 09, 2014, 06:57:10 pm
Here you go  :happy2:
TT/RS3 Top Mounts            8J0 412 331
Bearings for Top Mounts   6N0 412 249 C
Bolts                                  N 101 277 07
Post by: th3_f15t on July 09, 2014, 06:59:05 pm
Cheers mate. Just modified my original question! :P
Post by: biffobear on July 09, 2014, 07:01:26 pm
You may find that when removing old top mounts, the studs the nuts go on to will start turning and you will have to chisel/grind them off
Post by: SurreyED30 on July 09, 2014, 07:06:03 pm
My original top mounts spun and had to be grinded off when I first fitted the Coilovers late last year, when I swapped them out for rs3 mounts last month with the new suspension kit they undone easily. Most probally because they were only 6 months old. Rs3/TT mounts are definitely much better than oem gti ones.
I paid about £53 iirc for the whole lot from TPS
Post by: th3_f15t on July 09, 2014, 07:09:17 pm
Cool, that's a good price, seeing as ECS tuning sell a front mount kit for £100... Might drop a few quid your way and ask if you can pick me up a set from TPS? :happy2:
Post by: fab5freddy on July 09, 2014, 07:13:01 pm
No need to do the rear, front only  :booty:
Post by: SurreyED30 on July 09, 2014, 07:14:09 pm
Also seen ecs tuning for £100 and thought sh*t that's pricey wonder what tps or europarts charge so I got a mate to order mine through there works trade account, £53 was a good text message to receive when £100 nearly left my wallet :happy2:
*EDITED*
Post by: th3_f15t on July 09, 2014, 07:14:55 pm
Ah, fair enough. Might have to swing by the local Audi dealer with those part numbers and see how much they'll rape me.
Post by: SurreyED30 on July 09, 2014, 07:16:34 pm
Haven't you got TPS or europarts near you?
Post by: th3_f15t on July 09, 2014, 07:19:39 pm
I got a Euro Car Parts near, yeah... Will get on the website and search in a bit. I'm being slow and stupid tonight...
Post by: th3_f15t on July 09, 2014, 07:29:11 pm
Bolts                                  N 101 277 07
Is it;
2 Top Mounts
2 Bearings
6 Bolts
Post by: fab5freddy on July 09, 2014, 07:42:42 pm
Post by: th3_f15t on July 09, 2014, 08:22:05 pm
I also assume that I'd be much better walking into my local Euro Car Parts and speaking with someone and giving them the part numbers on a bit of paper?
Post by: Nodz on July 09, 2014, 08:22:37 pm
IIRC there's a TPS is in west horndon industrial estate
Post by: th3_f15t on July 09, 2014, 09:09:01 pm
http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Suspension/Installation_Kit/ES2718335/
Looks pretty good until you look at the price, but kind of suits my needs perfectly.
Post by: th3_f15t on July 10, 2014, 03:19:14 pm
So far PSI Tuning have quoted £110+VAT+PP (I reckon a final price of about £150), which seems pretty fair to me.
