All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Fozzie on July 09, 2014, 09:57:19 pm
Title: Rns510 aerial adaptor
Post by: Fozzie on July 09, 2014, 09:57:19 pm
When upgrading from a 2nd generation stereo (mfd2) to a 3rd generation rns510 I've read you need an aerial adaptor but
I've seen 2 types available one has a white plug and one blue plug and the other has a white plug and two blue plugs?
What's the difference? And which would I need for a
Rns510?
Title: Re: Rns510 aerial adaptor
Post by: paulw123 on July 12, 2014, 01:34:23 pm
this is the ariel lead adaptor you need
http://www.ebay.co.uk/itm/VW-Fakra-Radio-Antenna-Aerial-Adapter-RNS-RCD-510-310-315-Seat-Skoda-Columbus-/360808733867?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5401e05cab
Post by: Fozzie on July 12, 2014, 08:33:08 pm
That's good then because that's the one I bought!
Post by: golfmk5 on July 14, 2014, 06:33:07 pm
Also, if you have an early model mk5 with the black MFD2 (CD) you may need to bypass the aerial diversity control unit as well for optimal radio reception.
http://www.my-gti.com/1698/volkswagen-aerial-selection-control-unit-diversity-information
If you have to do that then this is the adapter you will need:
http://www.ebay.com/itm/110991091894
