All Things Mk5 => Mk5 General Area => Topic started by: Neon_skylight on July 16, 2014, 02:38:35 pm
Title: Is this normal?
Post by: Neon_skylight on July 16, 2014, 02:38:35 pm
Hi guys I have just recently purchased a VW Golf GTI mk5 with the dsg gearbox, it has only done 34000 miles and everything with it is perfect apart from I went for a drive in it today and Put it into sport mode and thought i could shift gears by pressing up and down on the lever but when I did it went to drive without me engaging the brake. After that I pulled over and discovered I could move from N to s and back again without touching the brake is this normal or should I get someone to check it out?
Any advise would be very helpful.
Title: Re: Is this normal?
Post by: Cooper on July 16, 2014, 03:53:54 pm
yes this is normal
Post by: ARV_90 on July 16, 2014, 04:49:04 pm
I do it all the time as I find D tends to want to get into 6th asap... slightly annoying when you come off an island and it goes up a gear. Then again manual on the paddles usually does it for me  :jumping:
It's a shame VW didn't put a variable setting sport so you could tame it down a bit... BMW smg box had it if I remember right.  :smiley:
Post by: Neon_skylight on July 16, 2014, 05:15:04 pm
Cheers for getting in touch I just find it strange that the brake has to pressed down to put it in park or reverse but I can move from neutral, drive and sport without touching the brake just touching the lever.
