All Things Mk5 => Mk5 General Area => Topic started by: imran359 on July 23, 2014, 03:00:53 pm
Took the filter off today to give it a clean and its literally just falling apart. Not even had it a year
Anyone else had this issue?
Is this a cone or panel filter?
Cone filter
I always felt that the foam filters are not as durable as other time tested materials.
Just search for replacement filters and check that the tube diameter matches and you'll be up and running in no time:
http://www.redline-motorworks.com/product_p/intkvffltr.htm
http://www.ngpracing.com/newstore/k-and-n-universal-cone-filter-3-inlet.html
http://www.ngpracing.com/newstore/k-and-n-universal-cone-filter-3.3-inlet.html
http://www.ngpracing.com/newstore/aem-dryflow-univeral-air-filter-2.75-inlet.html
Mine is doing the same i need a new one! Check its not falling apart inside you dont want to suck that up
What did you clean it with
Petrol
Was it falling apart before itg dont recommend petrol there filters are glued together
ITG does make their own cleaner, but I do not know what the solvent is.
Was falling apart before, itg do say petrol can be used as the adhesives used are petrol resistant
http://www.itgairfilters.com/downloads/cleaning-maxogenheavy.pdf
