All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: t20lau on October 30, 2009, 03:31:49 pm
Any difference between em?! Reason I ask is because I spoted a downpipe on ebay...
One slightly more expensive, which is for the edition 30,...so i take it there different?!
100% the same
If theres a difference in price mate it will be because one is 2.75inch and the other 3inch... Fitment will still be the same
HAHA!!! Just noticed...
Hmm...wonder which mine is (Cat-Back)?!
Guessing if I have a 3" Cat-Back, getting a 2.75" DP wouldnt work?! Or would there be a way to make it fit?!
If your a gti and not ed30 then the 2.75 will be fine, i think there are pros and cons for each size but the 2.75'' is specifically designed for the gti with the k03 :smiley:
Got the Edition 30...
:jumpmove: :jumpmove: 3'' then
Sorry for been thick, but are you saying I need the 3" downpipe and Hi-Flow Cat?!
Or that the Pipe size of the Cat-Back on the car is 3"?!
The standard full exhaust is 2.5'' so you want a 3'' dp either fitted to your standard cat back or get the full 3'' all the way...
I didnt want the full exhaust so i have the 3'' dp mated to the standard cat back, you still get the performance gains (most of them) and a bit of noise, nothing silly :happy2:
