All Things Mk5 => Mk5 General Area => Topic started by: s4seeker on August 15, 2014, 10:35:38 am
Guys - some more advice please if youd be so kind.
Had a quick search but nothing standing out.
My "check oil level" light" keeps coming on and guess what - the oil level is fine.
I had an S4 previously (and a TDI A4) that both suffered from faulty oil level sensors (bottom of the sump). Is the golf the same? If so I will get one for the next oil change and get that swapped too.
thanks again
Is it oil pressure??????
Pickup pipe.
Do NOT ignore it.
As above Do not ignore and keep on driving.
Oil level? Billy basic but check on firm level ground!
Oil pick up pipe
Or oil pump as above
It's the yellow 'check oil level' light that is illuminated?
An oil pressure issue will throw a red light.
Low pressure will be cause by; level too low, pick up pipe or oil line blocked or fault with the oil pump :happy2:
It could be the sensor. I had to replace the one on mine which cured it. You will also find it is tied in with the bonnet switch so it knows you have been in there to check. I knew the oil level was ok so used to just open the bonnet for a few seconds and close again to get rid of the warning then had the sensor changed during the next service.
Guys it is the yellow oil can warning and the message is "check oil level".
When I check the level (open bonnet) it goes off for a while. No red warning or anything to do with pressure I don't think.
I'll ask vw about a sensor.
Owners manual confirms priority 2 warning . Yellow oil can. It has a separate warning when low oil pressure detected (this text comes up in red).
Anyway checked with vw and they want £100 plus vat for the sensor so I'm going to try and check wiring etc is ok first.
Also got the part number so in can check online just incase anywhere else supplies them but I doubt it.
Thanks again!
This isn't always the case.
I had the yellow "check light" warning and it was my pickup pipe (I never touched the sensor) and the light has never come back on.
If I was you I wouldnt be leaving this.
Check light for what though? Pressure or level? Oil pressure and oil level are done by 2 different sensors. The one in the sump, which I changed only measures oil level and temperature.
The warning I am getting is for check oil level. Surely this means this is the issue or the sensor monitoring this issue is gubbed. Is it possible that the oil level warning is triggered by the oil pick up issue? If the oil pick up was the issue would the oil pressure not be affected?
How is the oil pick up pipe rectified?
Sump off job?
New sump gasket and pick up pipe?
Or should I be replacing the sensor first of all - ebay at £22.
Cheers again
To be fair, while the oil is drained and you're there changing the sensor, you're best getting the sump off and checking as per Jay's guide (sure he'll link it if I don't). Few hours work to fully check everything and potentially save your engine from death.
It was the check oil level (yellow light)
For peace of mind I'll Change sensor and oil next weekend , and carry out some checks if someone has a guide that would be great! I'll try a search for it later though.
If the pick up pipe needs "work" is if serviceable or are parts needed?
Thanks again
Just ordered pick up pipe from vw so I hope to do this one evening this week (it arrives on Tuesday).
Jay when replacing the sump would Granville instant gasket be ok as the sealer? I have this in the garage already and it says it does oil sumps.
I'm picking up oil/filter/degreaser/brake cleaner etc Monday or Tuesday too.
Might as well cover all bases eh - it's due an oil change and for the sake of another hours work and £30 for the pipe.
This is the part number for the genuine stuff if it helps
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fk482%2Ftfsi_mike%2F5b4c775d46a6068ab7ed52bb91f66dea_zpsb8cb08f7.jpg&hash=2b68101d9fb70978c99ac0d648d49e449c0a36bb)
A long 5mm Allen key with 'wobble' end or a wobble extension with 5mm hex socket will be needed. As a couple of he sump bolts are a bit awkward.
Thanks for the heads up. Will try these ones first just in case!
http://www.mk5golfgti.co.uk/forum/index.php?action=;topic=68442.0
Cheers! Pick up pipe should be waiting at vw for me. I've got all the other bits now.
Well had my first go at this today and got know where. I started with the troublesome 3 bolts and no joy. Need to get a socket piece that is more flexible tomorrow. Allan key approach with a wobbly extension didn't work either.
Am I right in saying there are also 3 torx screws to come out to drop the sump? Looks like on at the front and 2 drivers side attaching sump to air pipes I think.
Will try again tomorrow - hopefully after the first hurdle it will be easier!
These three bolts are the only difficult part of the job,whilst I never needed to use one of these extension i have done jobs where it's saved my bacon!
http://www.toolstop.co.uk/components/com_virtuemart/shop_image/product/AK7341.jpg
I assume your doing it off axle stands and on your back?
5 mm Allen key socket with wobbly head really makes job easier! There is also a cut out in the back of the flywheel to make the job easier. If you Turn the engine over by hand until the groove lines up with the bolts it allows you to get in at a straighter angle so you can get a better grip on them. (Seen quite a few come in with rounded off bolts which can be a nightmare to get out without gearbox removal!) cheers
That picture is what I was using effectively and just not enough bend on the end of it. Will try again tomorrow!
Got there in the end and all seems well, fingers crossed! Still to inspect old pick up pipe but new one fitted along with new level sensor. I have to say the top tip was turning the engine over by hand to align the notches allowing enough room for quarter drive wobbly head and 10mm socket.
3 torx screws to come out also, one at front and 2 drivers side.
Thanks for all the help!
Glad you got it done and fingers crossed will have sorted it. :happy2:
