All Things Mk5 => Mk5 General Area => Topic started by: keith on November 01, 2009, 02:50:59 pm
Can anyone advise if the brake line from the ED30 will fit the R32 I was going to buy G/hoses from another member but were not sure if they will fit my upgraded R32 set up. :happy2:
Goodridge hose's will plumb onto ed30 then onto your 32 brakes Keith :happy2: Got a set on mine :smiley:
i had 1stdibs on them but didnt knoe either :(
If your are talking about front brakelines then you need new ones, and as far as the back goes you are good to go with your original lines from the ED30, in fact anyone wanting rear R32 brakes on their GTI and want them in red, only need to buy r32/s3 carriers get them powdercoated red, buy a set of r32/s3 brakediscs, and you can reuse the rest ofyour standard GTI/Cupra rear brake setup.
TIP OF THE DAY :laugh:
Thats correct the hoses on the gti and ed30 are different to the r32.......on the front that is.
The rears are the same.
x2
Toast says yes, and has them fitted. The rest say no.
Keith,
The ED30/GTi front brakes use a Banjo union at the caliper,
This is a picture of my ED30 caliper brake line set up, taken just a few mins ago..........
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fv211%2Fstokeballoon%2FIMG_0862.jpg&hash=7de678cfd53ff750d35e8e0480afe88bb0d5cced)
You can see the banjo bolt at the end of the flexi line.
The below pic is courtesy of Chungster and shows the R32/S3/Cupra caliper and the small rigid line, which the terminates straight onto the flexi, no banjo union at all.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FChungsterGTI%2FGolf_GTI%2FMissingbrakepart.jpg&hash=43d56b3d9052b868a6decbaf576577d2068880f8)
Hope this helps.
What pads do you use as there will be a difference in disc thickness between solid and vented.
I've also read the S3 rear piston is 3mm bigger, so using the GTI caliper on S3 discs would make no difference surely as the same amount of pressure if being applied? Correct me if I'm wrong.
The GTI caliper on S3 Discs would not work. The vented S3 Disc is 25mm thick ( I think - It doesn't really matter) They are much thicker than the standard GTI solid unvented discs. so the S3 Caliper is wider than the GTi
Dave
The hoses on toasts car I supplied, they're goodridge jobbies that do away with the short connecting pipe and have a 35 degree banjo fitting and a M10x1 short banjo bolt and a couple of crush washers make a nice job you can see the hydraulic inlet on the R32 caliper is canted over at 35 degrees or so.
You can either P clip the hose to the M8 hole that the bracket goes into or simply pass the banjo through the hole that the short connecting terminates abeam with a rubber grommet to secure it and stop it rubbing.
Im sure you'll agree the less joins the better!
PS got loads of these PM if you need some
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fw69%2Fdave_brown1970%2FDSC00803.jpg&hash=f638103fd6313f6b07c1726465a47faa0b6c5f05)
Cool how much do the carriers cost and anyone got a p/n?
Read the posts below it Rob :happy2:
My new lines arrived today, they're under £6 each from the dealers now thanks to a supercession :smiley:
Oops my bad, should learn to read the full threads in future! :ashamed:
Its alright, we've all done it once or twice! :smiley:
