All Things Mk5 => Mk5 General Area => Topic started by: K9 on August 19, 2014, 09:06:17 pm
Title: Rcd510 need answer asap please
Post by: K9 on August 19, 2014, 09:06:17 pm
 :scared: hey, i'm bout to order a rcd510 oem from ebay and will be changing from a rcd300 -> rcd510. the golf gti is a 2005.
question is now that what gateway do i need to order and from where to avoide battery drain? can it be done without coiding anything? just plug-n-play the new gateway? :scared:
Title: Re: Rcd510 need answer asap please
Post by: Tortaruga on August 19, 2014, 09:22:03 pm
The gateway needs to be coded. PM Eddie NL on this forum as he sells gateways.
Post by: K9 on August 19, 2014, 09:23:26 pm
Thanks you! will do :drinking:
Post by: J400uk on August 19, 2014, 09:37:35 pm
Your choice is either buy a pre-coded gateway (contact EddieNL) or buy one and code it yourself using VCDS if you have access
