All Things Mk5 => Mk5 General Area => Topic started by: GTI-Ross on August 19, 2014, 09:35:08 pm
Title: Rear End Creaking Like Mad - Where is it coming from? Help !!
Post by: GTI-Ross on August 19, 2014, 09:35:08 pm
I have pretty stiff roll bars (H&R 28mm /24mm) so the chassis is very stiff , but the back end when driving on uneven roads is really creaky, starting to really do my head in.
I have had a played around in the back seats and boot and nothing seems to move or creak when pushing or pulling the parts. I have taken the rear seats out and some interior trim parts and its still there. I have tightened the hinges  and sprayed with WD40 ( I have since been told that white grease would be better, which i will buy & try).
Im pretty sure it not the rubber seals as it more of a chassis creak / flexing of the car. I have since even dropped my ARB setting to soft to try reduce it but its still there. It doesnt seem to do it if i drive wit the boot open.
Can anyone point me in the right direction or where to check next. Do the rear shock top mount ever creak as i havent checked there? It kind of sounds like its coming from C pilars or boot lid.
Someone has also said it could be the drop links causing the flex and the sounds travels through the chassis and makes it sound like its inside the car, what the best product to lube the drop links?
Thanks guys...
Modify message
Title: Re: Rear End Creaking Like Mad - Where is it coming from? Help !!
Post by: bacillus on August 19, 2014, 11:54:32 pm
It's possible the noise is emanating from your arb bushes in which case lubricating them should sort out the creaking.
Post by: cuprajake on August 20, 2014, 12:22:44 am
Mines the same bud.
Post by: Matto on August 20, 2014, 06:26:42 am
I'd go with the ARB bushes too as mentioned above. I've had to regrease mine 2 or 3 times now. The last time I just used a normal EP2 type grease which seems to be lasting a little longer.
Post by: GTI-Ross on August 20, 2014, 08:59:58 am
Well ill give it ago, but its just seems its the bootlid which is creaking / flexing, but I guess it could stem from the ARB bushing.
PS: where can i get some EP2 grease, Ive never heard of it or used it.
Post by: Matto on August 20, 2014, 11:04:11 am
Something like this should be work fine http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/grease/?526770030&0&cc5_150 (http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/grease/?526770030&0&cc5_150)
Post by: GTI-Ross on August 20, 2014, 11:40:24 am
Thanks for the link. It looks like it comes in a tube, do you use a silicone gun or something?
Post by: Matto on August 20, 2014, 11:42:19 am
You don't need one. Normally you can just take the cap of and use your finger.
Post by: GTI-Ross on August 20, 2014, 11:49:09 am
Ok cool, well i have one just in case. Thanks :happy2:
Post by: GS WAX on August 20, 2014, 12:19:58 pm
Check that the tailgate is not touching the top of the bumper when shut.
Post by: GTI-Ross on August 20, 2014, 02:56:05 pm
Think it might be a touch...how do you stop pr adjust it
Post by: Redemption on August 20, 2014, 05:18:09 pm
 Have a look here (and at the link to vwvortex in post #4).
www.golfmk6.com/forums/showthread.php?t=20784
Post by: GS WAX on August 20, 2014, 07:46:56 pm
Bumper off,or at best very loose,pull bumper cover away as much as possible,fixed most of the way along the back panel is a plastic guide rail,just below the rubber hatchback seal,another guide channel on the inside of the bumper locates into the one on the rear panel,these can become dislodged,causing the top of the rear bumper to raise up and  catch the bottom of the tailgate when shut.
will try and get some piccys of some of the parts to give you an idea.
Post by: GTI-Ross on August 20, 2014, 10:03:03 pm
That would be great if you could mate, thanks
