All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: K9 on August 27, 2014, 08:33:11 am
hey, just to confirm, can someone just copy past the right catbus gateway i need to prevent battery drain when swaping from rcd300 to rcd510. the car is a mk5 gti 2005. and i have genuine ross-tech
found a gateway K version, but only need to confirm that it's the right one before buying.
Open installation list and copy down everything that is ticked...
Fit gateway and then fill in the ticks onto the new list
Pretty simple
K revision should be fine...i have one for sale if your stuck!!
you got a PM m8 :happy2:
can you tell me in the pm what to do in vcds and what to copy
