All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: arris on September 02, 2014, 08:35:53 am
Title: Fitting turbo back down pipe and exhaust? Anything I need?
Post by: arris on September 02, 2014, 08:35:53 am
Right bought a turbo back down pipe and exhaust that I'm looking at fitting at weekend.
Is there any gaskets or bolts I should buy to replace at same time?
If so what ones or part numbers so I can order from TPS to have on the day.
Any other tips would be nice also :)
Rick
Title: Re: Fitting turbo back down pipe and exhaust? Anything I need?
Post by: rich83 on September 02, 2014, 09:33:05 am
Change the exhaust/turbo gasket for sure. I think thats good practice. Bolts should be ok to reuse
Post by: arris on September 02, 2014, 09:51:49 am
I thought that maybe the case.
I'll try get down TPS and order one  :happy2:
Post by: rich83 on September 02, 2014, 10:01:15 am
Alex uses high temp silicone on the joints of the exhaust too... so I would do that so it seals better and makes any later adjustments/removal easier.
Post by: Spankiee on September 02, 2014, 10:13:09 am
Anyone recommend which silicone to buy?
Post by: rich83 on September 02, 2014, 10:16:18 am
Google it. Black high temp silicone gasket. Loads to choose from.
