All Things Mk5 => Mk5 General Area => Topic started by: Gra on September 02, 2014, 09:20:14 am
Title: Problems
Post by: Gra on September 02, 2014, 09:20:14 am
Cars just hit 42k anything I should be prepared for? Ie common problems. Had belt and water pump done and engine mount. Anything I should change just to be on the safe side?
I see someone mentioned cam follower??
Title: Re: Problems
Post by: infernalant on September 02, 2014, 09:46:47 am
No harm is replacing the cam follower. Do you know what revision DV you have? Depending on version you may have a split & be leaking boost.
Title: Re: Problems
Post by: Gra on September 02, 2014, 12:36:54 pm
The latest one had it out other day checked it seems ok. Car runs really well for standard
