All Things Mk5 => Mk5 General Area => Topic started by: A1SGP on September 06, 2014, 10:18:02 pm
Title: Audi TTRS brakes
Post by: A1SGP on September 06, 2014, 10:18:02 pm
Can anybody tell me if the TTRS brakes will fit 18" wheels , or have you got to have 19"s . And to anybody that has them what do you think of them ?
Title: Re: Audi TTRS brakes
Post by: rich83 on September 06, 2014, 10:24:53 pm
18s will work but with OEM wheels youll need a spacer.
Post by: dansmith180 on September 07, 2014, 12:30:20 am
18's are tight supposedly not all 18's will fit over them (depends on design), you can get these calipers to fit onto R32 345m discs with some DaveB brackets
Post by: A1SGP on September 07, 2014, 08:44:30 pm
Cheers for the help , I'll be using the 18" pirelli wheels .
Post by: scooba on September 08, 2014, 06:37:10 am
I think I read the 18" BBS VZs work with bigger brakes
Post by: Stig_gti on September 08, 2014, 01:02:12 pm
What size spacers to fit 18" monzas
Post by: rich83 on September 08, 2014, 01:03:57 pm
I am using 8mm with pescaras.... so i would say 8-10 and yourll be fine.
Post by: Stig_gti on September 08, 2014, 02:01:13 pm
Post by: Stig_gti on September 09, 2014, 09:50:07 am
Would I need bigger then 8-10mm spacers if I'm running the calipers with r32 discs.
Post by: bluo on October 17, 2014, 11:23:24 am
Interested in this too! Any updates to your query??
Post by: rich83 on October 17, 2014, 11:23:59 am
Doubt it.
Post by: dansmith180 on October 17, 2014, 02:39:08 pm
The clearance is the same for the R32 and TTRS discs as the bracket is just an new carrier that moves the calipers closer into the disc. As for a review, they're f*cking awesome, I run them with drilled and grooved TTS discs (lighter than R32 ones) and Brembo sport pads and they stop hard time and time again I would highly recommend them.
Post by: George10 on October 17, 2014, 04:24:53 pm
You can fit them behind 18's with spacers, but it's the et on wheels you've got to be careful of.
Post by: TommyR on October 17, 2014, 05:10:04 pm
For an OEM wheel i.e ET51 and 7.5j on a 340/345mm disc you need a 12mm spacer. :happy2:
Post by: Stig_gti on October 17, 2014, 06:58:05 pm
What about pro race 1.2 et45 18"
Post by: dansmith180 on October 17, 2014, 07:01:26 pm
Assuming they're 8j then a 5mm spacer should be plenty, my wheels are 8j et45 and they clear by about 1mm or so and they have actually touched at some point  :sick:
Post by: Stig_gti on October 17, 2014, 10:21:12 pm
Thankyou :happy2:
