All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: danishmkvgti on November 05, 2009, 06:20:09 pm
Title: Morego ??
Post by: danishmkvgti on November 05, 2009, 06:20:09 pm
Anyone having experience with these kits???
http://www.morego.co.uk/product_details.php?id=3356&category=16
Title: Re: Morego ??
Post by: john_o on November 05, 2009, 06:28:46 pm
whilst they do work well, every report I have seen indicates rapidly increased tyre wear.
(due to permanent straight ahead neg camber)
they are the original arms cut and welded with a spacer piece
A better solution would be the WALKit which achieves a similar effect in a different way, but also leaves you open to add adj top mounts (to add -ve camber) at a later date.
I would err away from them.
check out tony danzas link in the  WALKit review (http://www.mk5golfgti.co.uk/forum/index.php?topic=395.0) which explains it better  :happy2:
Post by: tony_danza on November 06, 2009, 08:58:44 am
Do it the easy way and get some adjustable topmounts, that way you can dial it in and out to suit with 5 minutes and an allen key.
Whiteline Max C topmounts adjust for camber and caster.
Post by: danishmkvgti on November 06, 2009, 01:11:24 pm
Thx guys, saw this on the american forum and wondered why i hadn't read about it here. since it being a domestic kit. I'll have a look at whiteline,  :happy2:
Post by: danishmkvgti on November 06, 2009, 01:18:34 pm
Do you have a link to the whiteline max kit fitting the mk V gti platform??  :wink:
