All Things Mk5 => Mk5 General Area => Topic started by: AndyBrown on September 16, 2014, 06:37:17 pm
Title: Wing mirror puddle lights
Post by: AndyBrown on September 16, 2014, 06:37:17 pm
Has anyone changed these to LED?
Any photos?
Cheers.
Title: Re: Wing mirror puddle lights
Post by: Timepillow on September 16, 2014, 07:11:08 pm
I changed mine last week and what a difference they make well worth getting then!  :happy2:
Post by: Rossimac on September 16, 2014, 07:12:23 pm
Where did you get them from? Any ebay links and before/after pictures?
Post by: JoeDarKa on September 16, 2014, 08:22:27 pm
I would recommend getting the new full units rather than just putting led bulbs in. Not sure if iv got a pic of mine anywhere
Post by: alexharvey on September 16, 2014, 08:36:28 pm
had mine led for about a year
much brighter and look better there 501 led bulbs easy n cheap off ebay
Post by: JoeDarKa on September 16, 2014, 08:41:05 pm
I found the 501 bulbs gave out hardly anymore light over standard
Post by: skard on September 16, 2014, 08:41:45 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,62636.msg697544.html#msg697544
Here's a pic of my units, been in about 20 months no problems
Edit:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk99%2Fonlinephoties%2FE82ED531-8FB2-4814-97E3-38E826665BB8-6344-000003FA184EFC72_zps57226c6a.jpg&hash=95aa329b659b13dae90ca01c00216c818a9d11c3)
Post by: AndyBrown on September 16, 2014, 09:12:15 pm
What do you mean by unit? Why would you recommend that as appose to just swapping the bulbs?
Post by: mandeep_vw on September 16, 2014, 11:09:18 pm
Nice any better pics?
Post by: Shoy1980 on September 16, 2014, 11:19:50 pm
Full unit on mine also
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1336.photobucket.com%2Falbums%2Fo659%2Fshoy1980%2FMobile%2520Uploads%2FIMAG0743_zps432kquzp.jpg&hash=e1adedda262c158aabea89faaadb3a6cad32e1ac) (http://s1336.photobucket.com/user/shoy1980/media/Mobile%20Uploads/IMAG0743_zps432kquzp.jpg.html)
Post by: JoeDarKa on September 17, 2014, 07:03:25 am
http://www.ebay.co.uk/itm/2x-Error-Free-LED-Side-Mirror-Puddle-Lights-For-VOLKSWAGEN-GOLF-MK5-GTI-GT-R32-/221548562440?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item339552c808
Post by: Rossimac on September 19, 2014, 12:14:34 am
Bought!  :happy2:
Post by: Shoduchi on September 19, 2014, 02:00:59 am
Ordered them from aliexpress.com where they are a bit cheaper: http://www.aliexpress.com/item/2x-Error-Free-LED-Under-Mirror-Light-Puddle-Lamp-for-VW-Golf-5-Mk5-MkV-Passat/1830257334.html (http://www.aliexpress.com/item/2x-Error-Free-LED-Under-Mirror-Light-Puddle-Lamp-for-VW-Golf-5-Mk5-MkV-Passat/1830257334.html).
Thank you for the tip.
Post by: ARV_90 on September 19, 2014, 05:19:20 pm
Like the look of these  :smiley: Do you have to strip the mirror unit down to fit them ? Also do they come with a resistor pack or is it built in... Ah just noticed the ad say's MK5 ... or are the MK6 one's the same  :wink:
Post by: JoeDarKa on September 19, 2014, 06:47:27 pm
To change them you push the mirror the wrong way and out pops a tiny screw hole to undo them. Its plug and play with no errors
Post by: bbfb10 on September 19, 2014, 07:46:17 pm
My car oesnt have puddle lights, can these be retrofitted?
Post by: ARV_90 on September 19, 2014, 08:11:01 pm
Great thanks for the info... trigger pulled  :happy2:
Post by: Bennz on September 20, 2014, 12:04:56 am
How do you actually change them ?
Post by: ARV_90 on September 20, 2014, 08:38:42 am
They can be retrofitted but you will need the mirrors and controllers, guy on here called EddieNL may be able to help if you drop him a PM.
Post by: Stevie Steve on September 28, 2014, 10:07:00 pm
How about a ED30. Do I need to get the dremel out?
So do they plug and play and then need a recode?
Post by: JoeDarKa on September 28, 2014, 10:31:48 pm
My car never had the puddles fitted originally but they worked with just the coding. Cant tell if they will work until you plug them in though
Post by: lukemk5gti on September 29, 2014, 09:23:34 am
So when you remove the cover did you have an empty socket so it's just plug and play?
Had to code through vcds yes?
Post by: JoeDarKa on September 29, 2014, 01:05:27 pm
I bought replacement mirrors with the puddle lights in them and just coded them in
Post by: J12spk on September 29, 2014, 08:37:17 pm
Can't work this out, you got any pics?
Post by: JoeDarKa on September 30, 2014, 07:09:35 am
Usually the wing mirror folds into the car, towards the window?
To get at the puddle light underneath, you push it towards the wing
Like this:
http://tinypic.com/view.php?pic=nfk588&s=7#.VCpI1N2kqK0
This is if you have the puddles existing in your mirrors obviously. If you dont you need to either dremel the space out and connect them or buy some mirrors with the puddle light in
Post by: shaunnorris7 on September 30, 2014, 09:23:17 am
what type of bulb in needed??
Post by: R9OSW on September 30, 2014, 09:54:23 am
Standard puddle light is just a normal 501 bulb.
Can either fit an led 501 or go for full led unit.
I bought full unit. Cars now like blackpool illuminations at night now :happy2:
Post by: toosmiles on December 23, 2014, 02:06:38 pm
hey guys,
will these fit a golf R mk6?
thanks
Post by: Shoduchi on December 23, 2014, 03:40:21 pm
No, mk6 have a different shape puddle light.
You need something like this: http://www.aliexpress.com/item/A-pair-Direct-Fit-White-LED-Under-Side-Mirror-Puddle-Lights-For-VW-GTi-Golf-MK6/2047864209.html (http://www.aliexpress.com/item/A-pair-Direct-Fit-White-LED-Under-Side-Mirror-Puddle-Lights-For-VW-GTi-Golf-MK6/2047864209.html)
Post by: toosmiles on December 23, 2014, 03:55:26 pm
thanks for that m8 ;)
Post by: paulw123 on December 23, 2014, 04:24:20 pm
Have a look in the mods section
http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=113
Post by: ryangerry on December 27, 2014, 03:02:28 pm
I've bought some puddle lights from ebay (270994492333) and for some reason I can't seem to fit all the cabling back in as there is a little bit extra, has anyone else had this problem? I have the puddle lights already fitted in the mirrors and they are the electric heated ones.
Post by: AndyBrown on December 27, 2014, 06:12:52 pm
I had the same problem with the ones from aliexpress.
You can cut the plug off and join the wires together from inside the wing mirror housing, there's black line on the wires to join, worked ok for me.
Post by: paulw123 on December 30, 2014, 02:26:41 pm
i managed to fold the wires a bit and tuck it all back in, not alot of room tho
Post by: Rossimac on December 30, 2014, 07:06:30 pm
Yeah it looked like there was no way the wires would fold back in that tight space, but they did!
Post by: ryangerry on December 30, 2014, 07:09:10 pm
All fitted had to cut the wires and just wire them together and wrap in electrical tape all working now
Post by: RetroRaz on December 30, 2014, 07:52:59 pm
Have you got any pics of them working in the dark?
Post by: ryangerry on December 31, 2014, 07:55:56 am
Will take some this evening and post up but they look the bollocks
Post by: skard on December 31, 2014, 02:59:57 pm
Here are mine from a couple of years ago
Post by: RetroRaz on December 31, 2014, 04:36:32 pm
Nice one skard
