All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Broomy on September 17, 2014, 08:46:18 pm
Was giving the car a check over this evening for my MOT on Saturday & noticed a bit of oil on the under tray.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F18%2Fbupa9e4u.jpg&hash=c3abb80496384b2dde3a67568ecd32ce2c729221)
Whipped it off to see this.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F18%2F9ysuzu7u.jpg&hash=c95666367f2c8810f31e28a23e351e6cc893b890)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F18%2Fu6e9agy3.jpg&hash=11db27f3735d510888b8e0c3f80cf3d3845e87f5)
Just in from the screws that hold the under tray on the n/s.
I did some searching before posting & it seems to be the inter cooler pipe?
Can anyone confirm or advise what could be leaking? No patches on the drive but would rather get it sorted.
It does use some oil but I thought the mk5 GTI did use a bit? I didn't think it was overly excessive. 1tr per 2/3 mths.
Cheers.
Very common leak - mine does it. You can buy a new washer for pennies at a dealer :happy2:
Mine had the same thing but the pipe looked like it was seated OK. Is this oil from vaporised oil that is re-entered into the intake system via the PCV? Can not work out how oil ends up in the inter cooler intake?!
Thanks for the replies.
Phew that's a relief, haven't a clue how it gets there , will have to get it sorted though castrol edge isn't cheap.
Can that just be unclipped & seal replaced on the drive?
I'd check your intercooler make sure it's not filled up with oil that's a lot of oil to come out a intercooler pipe there should only be a small amount
You need to replace the hose, C clip and o ring seal (on both ends).
It's approx £65 from VW.
Or you can cut the bayonet fitting off the pipe, and buy an adaptor from somewhere like Creation Motorsport on eBay for £20 delivered and save yourself a fair few quid, just needs a jubilee or T-bolt clamp, and the o-ring and c-clip which are a couple of quid tops on their own :happy2:
That joint is about to blow! I bet the lugs are worn on the hose, as above get a new hose and seals or adaptor. I went the adapter route on eBay search boost bayonet
+1
I had the same problem a few months back.
In definite need of proper fitting again...you are losing boost. The oil is normal but not if it appears to be an excessive amount. It should only lightly coat things if at all. Also, if oil is excessive there, you may have a cracked EVAP portal in the valve cover allowing oil to be sucked into the EVAP line that goes into the turbo inlet...but you will notice excessive oil usage and smoky exhaust at high revs and under boost. See my post if this may be the case:
http://www.mk5golfgti.co.uk/forum/index.php/topic,88806.msg900231.html#msg900231
I wouldn't know how to start & butcher bits, I'll order the replacement parts.
Intercooler hose? X2
Intercooler c clip x2
O ring seals x 2
Cheers for the input, appreciated.
One intercooler hose.....
Give me your email and I'll forward you etka info tomorrow..
Cheers buddy, PM enroute.
Is this likely to be an MOT failure? I need to reschedule before 12 tomorrow to avoid losing out on the fee.
Clean it all up as best you can and it should be ok
Scrubbed the under tray with neat fairy liquid, will give the pipe work a clean up & see how she fares. Thanks
No.
No.
Exactly this.
Its not safety related
Cheers, now I can relax a bit.
Before I press the button on these can someone confirm I have ordered the right amount of the right seals?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F20%2Fetenetab.jpg&hash=fb0dc91534282b1bf36f62a985ac1c7e815d50dc)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F20%2Fmusapyte.jpg&hash=3d9b51f9fd7d243f1c009e552cc6528c203c8829)
For anyone coming across this in a search I found this pic helpful to understand how the clips work (not mechanically minded).
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F20%2Fe7u5yma2.jpg&hash=d4f4122c5bc0d6db259c09a347051c5084145385)
will not fail mot it should be fine
I have a set I am selling from a gti I have broken up for spares I have now listed them on ebay :happy2:
they are listed on the forum as well :wink:
]http://www.ebay.co.uk/itm/111468050445?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649] (http://www.ebay.co.uk/itm/111468050445?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649)
Cheers bud but I'm going to replace them with new parts for piece of mind.
Fingers crossed for today.
Edit- she passed with flying colours :)
Nope. They can't remove engine covers to inspect, so don't worry.
I have a similar issue on the opposite side to you, passed an MOT. Thinking that I may as well replace both the pipes and intercooler while I'm doing other intake parts, but that's part of a secret plan I'm forming...
Passed today thankfully, no mention of it :)
Think I might replace the hoses with this
http://www.amazon.co.uk/dp/B0089CC6V2/ref=cm_sw_r_udp_awd_O3yhub1PAVWKD
The jubilee clips should hold out a bit better than OEM.
They look good, let us know if you use them.
The jubilee clips don't replace the oem spring clips, they secure the alloy ends to the silicone pipes... Should imagine it would be a good replacement thought :happy2:
Here's a pic of the bayonet type fitting, just cut old end of and insert (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F09%2F23%2Fy9yqe9yt.jpg&hash=0c041a4550b7cb600683d5dedf0279c5bc62fd7c)
Delete
Delete
Delete
Delete
Delete
Delete
Delete
Delete
Delete
Sorry, is that a pic of the bayonet type fitting? :grin:
Holy mother of tapatalk SORRY
Lol cheers for the pics buddy
Thankfully the amount leaked since I posted this thread was minimal but I changed the o-rings this afternoon for piece of mind. Pipes & lugs were grand no need to change them. Thanks for all the help :)
