All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: ChrisGti on September 19, 2014, 10:24:17 pm
Good evening Gents, Does anyone know what the part numbers are for the bolts on the lower control arm rear bushing bracket? It uses 3 bolts per side, of which two are the same.
I think they are M10 & M12.
do you mean the console bush bracket bolts
http://thumbs2.ebaystatic.com/d/l225/m/mtWASvyRhIfQgI3PcxFpcqg.jpg
if so 12mm is N 91039802
10mm is N 10579702
Yes! Thanks a million.
