All Things Mk5 => Mk5 General Area => Topic started by: stuupnorth on September 22, 2014, 11:11:46 am
Title: ok I know......
Post by: stuupnorth on September 22, 2014, 11:11:46 am
Ok guys
the chestnut......which oil would be best for my 2005/6 gti
it's done 110k the oil has been changed regularly is it time to use 5w-40
or stick to the 5w-30?
by the way it's bog  standard
cheers
Stu
Title: Re: ok I know......
Post by: th3_f15t on September 22, 2014, 11:52:26 am
I've started using 5w-40 as it's able to deal with higher engine temperatures seen on turbo charged engines (if I'm correct). If you like to use the full rev range, perhaps 5w-40 would be better long term, but otherwise there's little, if any, different at standard tune.
Correct me if I'm wrong though, I only know the real basics.
