		All Things Mk5 => Mk5 General Area => Topic started by: Georrge on September 22, 2014, 09:33:33 pm
				I had highline clocks fitted recently, I believe they end in 972 from memory. I don't have a MFSW, but it is something I will get in the future, preferably a MK6 one  :smiley:
But is there a way to access the other menus with the stalk? I can obviously toggle between average MPG, miles left inb tank etc with the up down button, and I've tried holding them down to see if that does anything but no luck.
Thanks!  :happy2:
				Yes you can...
You either press and either the up or down button or press the button underneath the stalk (set up). I can't remember which but its the ssme set up i had on my old TDI.
				I just tried all of that and had no luck. I tried just a simple press, I also tried a press and hold. Here is a quick video demonstrating:
				Very odd. It was holding the up or downbutton on the end that did it.
Maybe your cluster PN is wrong for use with indicator stalk
				I've had highline clocks fitted as standard and only ever switched between average MPG, range ect. I'm going to have a play tonight and see, as I don't (nor ever have had) a multifunction steering wheel...
That's what I thought I had read previously! Oh well it's no big deal really as I will one day get a mk6 mfsw.
Do you think changing my stalk would fix the problem?
 Let me know if you can access it :)
				What are the other menus I should be able to access and how do I do it? Sorry for the very stupid question, never come across this before now.
This shows some of the menus
http://www.myturbodiesel.com/wiki/multifunction-display-mfi-or-mfd-faq-and-menu-settings-mk5-mk6/
				How the hell did I not know of these toys in my car before now?! Where's my keys..? :laugh:
				Haha, let me know if you can access it! There is lots of little things you can change with the menus  :happy2:
				Need to consult the hand book and work out how to get to these menus... I'm going to hold various buttons and see what happens.
				Just watch the video I posted earlier on this thread, one of those methods should work. But doesnt for me as I retro fitted them
				Yeah, mine worked by just pressing on one of the end buttons on the stalk (like you did in your video). Does it need setting up with VCDS then if your retro fit?
I'm glad yours is ok! Enjoy your new features haha. Yeah it needs coding, it was coded correctly but someone but as mentioned earlier on, my stalk isn't the correct [air with the clocks.
				Hi George,
Sorry to bring this ancient thread back up, but wondering if you found a solution to this issue? I'm having the exact same issue, I recently upgraded from midline to 972 Highline clocks, I don't have mfsw and can't access mfd via my stalk driving me insane.
Hi George,
No need to apologise, that's what the admins on here want you to do!
But as far as I'm aware, the solution is to get a MFSW. I'm planning on getting s mk6 wheel, just waiting for the right one to pop up  :happy2:
Hi George,
Same here. I am having the same problem...
It appears you might need a highline CCM, but that didn't work for me: http://www.mk5golfgti.co.uk/forum/index.php/topic,93756.msg943026.html#msg943026
Hi George,
Interesting, I never knew you could change them. Let me know if you get it working or not later!
				Thanks for the info guys, this issues really annoying. I'll be installing a mfsw in the near future, but I was hoping I could still use my stalk to access the mfd for now! Damnit
If you guys come to find a solution give us a shout. Cheers
				I don't think you need a highline CCM..
on my old 1.9 TDI it was a 2004 se with cruise control etc.
highline cluster fitted and controlled from indicator stalk no issues..?
 :ashamed:
 :ashamed:
Then why don't it work for me  :sad1:
 :ashamed:
It depends on what clocks you get from what I've been told. I have cruise control too, but can't access menu
				did you try a different indicator stalk....?
				if you have a later style cluster, wiper stalk wont work. you will need a mfsw. Happenned to me on my 973 clocks. on my old golf I had a 971 cluster and wiper stalk worked.
				Hi raz,
The cluster I got installed is a 972, so it should work shouldn't it? The SatNav instructions appear on the mfd (directions, compass etc) however, track info and radio info doesn't and I can't access the mfd via stalk.
Hi raz,
what happens when you hold the up or down position for about 5 seconds?
I thought u had a 973 fitted?
				oh sorry I mentioned 973 to you, but that was my mistake, it's a 972 cluster off Jedi's 55 plate GTi.
Holding up/down for about 5secs does nothing, just the same as if I was to press it once up/down (go to the next item ie. mpg, range etc)
				From the research and reading I've done on this issue everything seems to indicate that I should be able to access the settings menu etc especially considering that its a 972 cluster and not a later 973/4 cluster.
Could it possible be just a coding error? The vehicle the 972 cluster came out of had mfsw and mine doesn't. Hmm
