All Things Mk5 => Mk5 General Area => Topic started by: lukemk5gti on September 23, 2014, 09:32:39 am
Title: Conincidence? Both CV Boots Gone!!
Post by: lukemk5gti on September 23, 2014, 09:32:39 am
So I decided to opt for a full VW dealer service on the basics... They sent me a video before I collected the car to say my passenger side CV boot was weeping which I was not aware of.
I'd be fairly up to speed on car mechanics and wouldn't miss something like this! In fairness the weep was minor and hardly any grease showed up so I'll accept that it was fresh enough. They quoted €130 to repair that day so instead I took it home and installed a new boot myself which is perfect!
This was only last week!! When washing the car on Sunday I walked by the driver side wheel and there's grease residue so I checked. I found now the driver side CV boot is also split. What are the chances that CV boots last for years on end but now both go within 7 days of one another?
Am I being paranoid or would VW have damaged it whilst doing work (by accident)? Or is this just a freak accident?
Title: Re: Conincidence? Both CV Boots Gone!!
Post by: xjay1337 on September 23, 2014, 09:36:28 am
I would say paranoid.  :signLOL:
Post by: dazza on September 23, 2014, 11:00:26 am
I've had my car since march. One outer boot was ripped when i got her since then the other outer and an inner have ripped.
Post by: OEM+ DUB on September 23, 2014, 06:14:14 pm
Both of mine went at around the same time last year - one I found when taking a wheel off and the other went in the following week whilst waiting to get the first done.  Ended up having 2 new genuine boot kits installed at the same time.
Post by: th3_f15t on September 23, 2014, 06:19:23 pm
Could of damaged it while inspecting it would be my guess. Both old, perished rubber but the other one was OK till someone poked it. Just bad luck really!
Post by: homesqueeze on September 23, 2014, 06:36:29 pm
Had both mine go at very close intervals with no outside interference.
Post by: lukemk5gti on September 23, 2014, 07:01:22 pm
I was actually going to write that in the original question because I knew someone would point it out!
Good spot but when I inspected it was completely invasive. Didn't touch it at all, just spun the wheel with a torch on it to look for grease!
So it seems quite common for both to together anyway.
Bought another boot there so will replace tomorrow
Anybody need a guide? I was thinking of writing a very brief one only as an assistance to the Haynes manual!
Post by: dazza on September 23, 2014, 07:17:08 pm
Did the cv joint come off easy in the end?
Post by: lukemk5gti on September 23, 2014, 08:06:45 pm
Very easy yes.
Angle the joint out so you can see the bearing.
One hard accurate whack and it'll come loose
Post by: dazza on September 23, 2014, 08:30:41 pm
Very easy yes.
Good for you my car does not believe in karma nothing ever goes as planned.
Post by: J400uk on September 23, 2014, 08:52:22 pm
Mine both went at the same time, also detected by a VW main dealer. Its an MOT fail if you don't fix it so will need doing!
Post by: lukemk5gti on September 24, 2014, 09:03:24 am
Very easy yes.
In fairness I was outside sitting in front of the joint for an hour hitting it tiny whacks from different angles, googling different ways to remove it and trying to take off the inner boot before I got fed up and said what's the worst that can happen.
If I damaged it I could get a new joint so I lined it up and whacked it. Got it first time but just took some courage.
Don't hold me to this but I think Haynes manual said to WD40 it up before refitting the spline so that it will come out easy should you need to change again.
I could be wrong on this and it may actually cause it to slip in the future so don't dare sue me! I'm just trying to think back on manual.
Have parts picked up now to do second one. Will start this evening after work. Going to remove suspension while I'm there and take a look.
Also might examine the DV I installed a month back.
Post by: dazza on September 24, 2014, 11:55:20 am
Very easy yes.
Thanks for that mate good to know i was not the only one that did not get it off first go.
