All Things Mk5 => Mk5 General Area => Topic started by: bbfb10 on September 24, 2014, 12:38:02 pm
Title: Highline Clocks Part Numbers
Post by: bbfb10 on September 24, 2014, 12:38:02 pm
Ive read on various forums the 'how to's' etc and I know that my current Midline dash (962) should be replaced with a 972 Highline unit.
My question is; is this the only part that can be used?
Can I not use 973 or 974 clocks?
What about 972 clocks from a Jetta (for instance) or are they a different shape/fitment?
Are any other part numbers compatible? Ive scoured eBay etc for 972 clocks to no avail so any help would be great.
Thanks.
Ben.
Title: Re: Highline Clocks Part Numbers
Post by: RetroRaz on September 24, 2014, 01:12:03 pm
you can use 970 971 972 973 or 974
970 971 972 are easier to code. 973 and 974 has to be coded by Eddie_NL or Kalu as they have the correct equipment to do so.
If you want to use your mfsw to control the clocks, you will need a 973 or 974 or you can use the wiper stalk rocker buttons.
You can use jetta ones too
