All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Stevie Steve on September 30, 2014, 12:35:58 am
Title: looking to swap in RNS510 - lots of questions
Post by: Stevie Steve on September 30, 2014, 12:35:58 am
Looking at replacing my RCD300 at some point with a good old RNS510. So Im right a the bottom of the learning curve with this one.
Reading version D, adding RDS, dvd drive and loadsa other bits.
Does it plug and play into a 08 plate ED30. What does/can it give me from standard. What do I need to add to get sat nag or even reversing cameras (I think)
Title: Re: looking to swap in RNS510 - lots of questions
Post by: Viking on September 30, 2014, 06:58:08 am
RCD300 comes out, RNS510 goes in, aerial adapter and GPS antenna required. Bit of coding with VCDS, and you're done. Whereabouts are you?
