All Things Mk5 => How to Guides / Troubleshooting => Topic started by: ed30sam123 on September 30, 2014, 04:50:19 pm
Title: DSG Reset - New owner
Post by: ed30sam123 on September 30, 2014, 04:50:19 pm
Hi all,
I know DSG learns how the driver drives, does it re-learn when a new owner starts driving the car or is a DSG reset recommended?
Sam
Title: Re: DSG Reset - New owner
Post by: K9 on September 30, 2014, 05:22:24 pm
my guess is that it need to be reset  :innocent:
as i need to do this to using vcds
Post by: bigtop on September 30, 2014, 05:25:44 pm
Iv heard theres a way to reset using ignition?
Does this work, and if so, how do you do it?
and is it ok to do it with a dag map? Will it affect the map?
Post by: dazza on September 30, 2014, 05:39:11 pm
It relearns. Drive it hard for a little and you will notice the difference.
Post by: ed30sam123 on September 30, 2014, 06:43:48 pm
Cheers guys, so the best bet is to drive it hard for a while and it will Adspt to the way a drive? So is there no benefit to a reset?
Sam
Post by: jbenekeorr on September 30, 2014, 07:50:03 pm
You can do a reset by sitting in the car, key in your hand - floor the accelerator all the way and hold it there. Put the key in and turn it so that the lights come on the dash and keep your foot down for at least 30 seconds.
It will then go back to 'default' and learn your driving style.
That's all - done it on mine, a MK6 and a 13 plate A3. I don't know if it's a full reset like one done with VCDS but it totally changed mine. Cured the jerky reverse and first gear.
Post by: bigtop on September 30, 2014, 08:07:39 pm
And this wouldnt affect a dsg map?
I have no jerkyness or anything but sometimes its a bit slow responding e.g if i have my foot off acc slowing for a rb, then i change down a gear to accelerate, theres a slight delay, where as normally its instant
Post by: dazza on September 30, 2014, 08:19:10 pm
If your changing down i doubt its anything to do with the dsg learning. Having never driven an auto let alone a dsg it was strange at first. Are you driving in manual mode/D or S.
Post by: bigtop on September 30, 2014, 08:49:25 pm
Manual mode
Its only a slight delay, and only get it occasionally
Mite try a reset
Post by: dazza on September 30, 2014, 09:01:00 pm
This is a good read may help with a few pointers.
http://www.golfmkv.com/forums/showthread.php?t=69511
Post by: ed30sam123 on September 30, 2014, 10:26:07 pm
Excellent, thank you, I will give that a go  :smiley:
Well worth the read, gives drivers new to DSG a much better understanding of the box and how to use it.
Cheers  :happy2:
Post by: anders8n on January 05, 2015, 10:46:46 pm
Does anyone know if this reset could clear a DSG remap? Cheers.
Post by: anders8n on February 21, 2015, 01:33:37 pm
Anyone?
