All Things Mk5 => How to Guides / Troubleshooting => Topic started by: ibbyem on October 06, 2014, 04:39:46 pm
I think my car is now in limp mode doesnt rev over 4000 RPM and has no turbo kicking in, after doing some research i found out it is in limp mode
after connecting a vagcom to the car i came across all these faults
need help with this ASAP
Monday,06,October,2014,16:14:03:62939
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 Q HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0403000318070160
Work Shop Code: WSC 01279 785 00200
VCID: 3467FA5B57CEB4BE40B-8061
6 Faults Found:
012691 - Intake Manifold Runner Control
P3193 - 002 - Open Stop outside of Valid Range
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1077 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
P1098 - 001 - Open or Short to Plus
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1041 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
012423 - Voltage Supply Relay for Engine Components
P3087 - 002 - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1018 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 14.097 V
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:27
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
000581 - Solenoid Valve for Boost Pressure Control (N75)
P0245 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:27
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 14.097 V
Readiness: 0110 0101
that's a nice start, join the forum and immediately ask for help, ever thought of maybe saying hi and introducing yourself first?????
I saw another post this morning just by chance with similar symptoms. Given your VCDS scan shows problem with N75 it's probably your first bet.
http://www.mk5golfgti.co.uk/forum/index.php/topic,89543.0/topicseen.html
@DDM (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=7941) sorry lol, first time every using these forum things
could one of the reasons be that it hasnt got the right battery for the car?, because my battery isnt for this car but it starts it and everything runs fine
