All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Riz_mkv on October 18, 2014, 03:02:09 pm
Title: Cruise Control Retrofit
Post by: Riz_mkv on October 18, 2014, 03:02:09 pm
Just fitted cruise control on to my car and tried to code it, however on VCDs in Engine "Coding ii" will not allow me to select it and under fault code it comes up with Error P0568 - Cruise Control Switch (E45): Implausible Signal
Can anyone help me as to why this is happening
Title: Re: Cruise Control Retrofit
Post by: RetroRaz on October 18, 2014, 03:04:25 pm
Was the cruise control wire fitted?
Post by: Riz_mkv on October 18, 2014, 03:16:47 pm
I wasn't provided with any wires just the cruise control stalk as I believe that's all I needed and some coding :/
Post by: RetroRaz on October 18, 2014, 03:22:47 pm
What year is your golf?  I think 2006 onwards came with the wire fitted from factory
Post by: Riz_mkv on October 18, 2014, 03:31:07 pm
Yeah my car is 2006
Post by: tfsi_syncro on October 27, 2014, 01:26:29 pm
You may have to change the steering wheel control module depending on what variant you currently have. When you run a scan in VCDS you should be able to see which one is currently in your car.
Also bare in mind that you will need to make sure you select one that is compatible with your slip ring.
Use the link below to determine which one you will need or to confirm that you already have the correct one in place.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
